Launching AutoCad Issue
mgorecki
Message 1 of 34
mgorecki
I have another program that will launch this code below (admittedly, I got it from "Through the Interface")
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
'Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Imports System
Imports Autodesk.AutoCAD.Interop
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Internal.Forms
Imports System.Windows.Forms
Public Class launchAutoCad
    Public Shared Sub StartAutoCAD()
        ' "AutoCAD.Application.17" uses 2007, 2008, 2009
        '  whichever was most recently run
        ' "AutoCAD.Application.17.1" uses 2008, specifically
        ' "AutoCAD.Application.18" uses 2010, 2011, 2012
        ' "AutoCAD.Application.18.1" uses 2011, specifically
        ' "AutoCAD.Application.19" uses 2013,...
        Const progID As String = "AutoCAD.Application.18"
        Dim acApp As AcadApplication = Nothing
        Try
            acApp = DirectCast(Marshal.GetActiveObject(progID), AcadApplication)
        Catch ex2 As Exception
            Try
                Dim acType As Type = Type.GetTypeFromProgID(progID)
                acApp = DirectCast(Activator.CreateInstance(acType, True), AcadApplication)
            Catch ex As Exception
                MessageBox.Show("Cannot create object of type """ & progID & """")
            End Try
        End Try
        If acApp IsNot Nothing Then
            ' By the time this is reached AutoCAD is fully
            ' functional and can be interacted with through code
            acApp.Visible = True
            acApp.ActiveDocument.SendCommand("(command " & Chr(34) & "NETLOAD" & Chr(34) & " " & _ Chr(34) & "C:\\mystuff\\myprog.dll" & Chr(34) & ") ")
        End If
    End Sub
End Class
At the first "Try" it will throw an exception because AutoCad is not running.
In the second "Try" we have:
Which launched AutoCad (it shows up in the task manager).
But still, it then goes into the next "Catch" and the message box says is can't create that ype of object.  But I can see that it launched AutoCad.
So I copied the line:
and forced it.  It worked.
Why would it throw an error if it did what it was supposed to do?  I see so many people using this same code on many different forums, but I can't understand why it doesn't work for me.
Thanks, in advance.
Replies (33)
Message 2 of 34
fenton_webb
It's really difficult to say what the problem might be. Usually, when you have issues with COM not working as expected it's because the installation is corrupted somehow...
Here's what I would advise...
1) Uninstall all Autodesk products
2) reinstall in chronological order.
Fenton Webb
AutoCAD Engineering
Message 3 of 34
Alexander.Rivilis
Try this solution: http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
P.S.: Are you trying to use AutoCAD .NET API from external exe-file? It is impossible.
E.g. those namespaces can be using only from  dll-file netloading into AutoCAD:
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 34
fenton_webb
"those namespaces can be using only from  dll-file netloading into AutoCAD"
Not necessarily - you can import .NET DLLs that are dependent on another EXE as a reference to its types only (the dependencies will be ignored). This is particularly useful when using reflection.
Fenton Webb
AutoCAD Engineering
Message 5 of 34
mgorecki
I've gotten around the thrown exception by changing the code as shown:
    Public Shared Sub StartAutoCAD(ByVal rad As String)
        Try
            ' Get a running instance of AutoCad
        Catch 'ex As Exception
            Try
            Catch 'ex2 As Exception
                If IsProcessRunning("acad") = False Then
                Else
                End If
            End Try
        End Try
            'acApp.ActiveDocument.SendCommand("(command " & Chr(34) & "NETLOAD" & Chr(34) & " " & _
            '                    Chr(34) & "C:\\mystuff\\myprog.dll" & Chr(34) & ") ")
            Dim AcadDocs As Object = acApp.GetType().InvokeMember("Documents", Reflection.BindingFlags.GetProperty, Nothing, acApp, Nothing)
            ' Create array of parameters
            Dim filename As String = "temp.dwg"
            Dim args() As Object = New Object(1) {}
            args(0) = filename
            args(1) = False 'read-only=false
            ' open a drawing
            Dim AcDoc As Object = AcadDocs.GetType.InvokeMember("Open", Reflection.BindingFlags.InvokeMethod, Nothing, AcadDocs, args, Nothing)
            Dim Util As Object = New Object
            ' Get reference on active document
            AcDoc = acApp.GetType.InvokeMember("ActiveDocument", Reflection.BindingFlags.GetProperty, Nothing, acApp, Nothing, Nothing)
            ' Get reference of  AcadUtility
            Util = AcDoc.GetType().InvokeMember("Utility", Reflection.BindingFlags.GetProperty, Nothing, AcDoc, Nothing)
            ' Get reference on ModelSpace
            Dim oSpace As Object = AcDoc.GetType.InvokeMember("ModelSpace", Reflection.BindingFlags.GetProperty, Nothing, AcDoc, Nothing)
            ''********************************* draw circle **************************
            Dim center As Point3d = New Geometry.Point3d(0, 0, 0)
            Dim radius As Double
            radius = (CDbl(Val(rad)))
            DrawCircle(center, radius)
        End If
    End Sub
 I have a function defined (IsProcessRunning) that works for this.  It actually checks to see if the process "acad.exe" is actually running.
I am launching the dll from an exe currently (for testing) eventually it will be a web app.
I do have another issue though, I was just trying to pass the dll a string (just to see if I could)
In the calling .exe:
Module Module1
    Sub Main()
        Dim rad As String = "12.5"
        launchAutoCad.launchAutoCad.StartAutoCAD(rad)
    End Sub
End Module
 I get the following error:
Could not load file or assembly 'acdbmgd, Version=18.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Any help clearing that one up would be greatly appreciated.
Message 6 of 34
fenton_webb
By the way, to refect the types without resolving the dependencies... Do this:
Assembly.ReflectionOnlyLoadFrom()
Fenton Webb
AutoCAD Engineering
Message 7 of 34
Alexander.Rivilis
Hi, Fenton!
Are you saying that I can use the classes / methods of acdbmgd.dll, acmgd.dll, accoremgd.dll from external exe-file??? You're kidding me? 😉
Otherwise I do not see any reason to load these assemblies in the exe-file if I can not use the dll-files (ie to execute code from them)
Expert Elite Member
Message 8 of 34
Alexander.Rivilis
@mgorecki wrote:
... I get the following error:
Could not load file or assembly 'acdbmgd, Version=18.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified...
That's because you're trying to use the classes / methods from acmgd.dll from external exe-file instead from dll-file loaded into AutoCAD. Point3d is a class defined in acdbmgd.dll
Expert Elite Member
Message 9 of 34
mgorecki
Hi Alexander, can you tell me how to resolve this?  I have been writing VB.Net code, but always ran the code in an existing AutoCad session, never like this.  This is all new to me.
Message 10 of 34
mgorecki
Hello Fenton,
This is going to sound stupid, but, what do I do with that?
Message 11 of 34
fenton_webb
I'm not kidding, Alexander!
Fenton Webb
AutoCAD Engineering
Message 12 of 34
mgorecki
I do not have a reference to the acmgd.dll file in the .exe "References".  I do have a reference to the launchAutoCad.dll though.
 After all, I'm just sending a string, not attempting to launch any AutoCad commands.
Message 13 of 34
Alexander.Rivilis
Hi, Fenton!
Then
please explain what you mean. Preferably with an new example on http://adndevblog.typepad.com/autocad/ and with title: "How to use AutoCAD .NET API assemblies out of acad.exe process"
Expert Elite Member
Message 14 of 34
Alexander.Rivilis
And launchAutoCad.dll has reference to acdbmgd.dll and/or acmgd.dll? If so - than it is identical that .exe has reference to those.
Expert Elite Member
Message 15 of 34
mgorecki
Ok, I give.  I removed the reference to launchAutoCad from the references and now the line:
launchAutoCad.launchAutoCad.StartAutoCAD(rad) says "launchAutoCad is not declared...."
I've looked all over, Googling everything I can think of that would relate.  I'm not asking for you to write the code, but can you please point me in the right direction?
I've looked at declare and DllImport, but either I don't understand, or it just doesn't apply.
Message 16 of 34
DiningPhilosopher
Hi Fenton.
If I'm not mistaken, there is static initialization occuring in AutoCAD's managed assemblies or native DLLs they link to, and that would mean that code executes at the point when the assembly or one of its dependents is loaded, and would prevent it from being loaded into any process, whcih would be triggered by any attmept to reflect on any contained types.  You can use ReflectionOnlyLoadFrom() to load a DLL as a data file, which allows you to access its metadata, but that's not the same as referencing the assembly in an .exe project.
If i'm mistaken, then I'd like to see an example of this.
Message 17 of 34
mgorecki
Hello, can you help me out?  I have an exe that is supposed to launch a dll and pass the dll an argument (in this case an array).
At first I was just trying to get the exe to run the dll which launches AutoCad.  Now that it works, I want it to send an array of strings to the dll so that after AutoCad launches it can execute the program and create my drawing (using the info from the array).
Here is the .exe.  I've doinked around with it a bunch and this is it's present condition:
Module Module1
    Declare Sub test Lib "C:\_svn\launchAutoCad\bin\Debug\launchAutoCad.dll" Alias "StartAutoCAD" (ByVal rad As String)
    Sub Main()
        test(rad)
        'launchAutoCad.launchAutoCad.StartAutoCAD(rad)
    End Sub
End Module
 It used to just be the commented out line, but when I wanted to pass an array, it choked on a reference to an AutoCad dll (one of the reference dlls that get loaded into the program in References).  Since the exe didn't have any of those references, it was choking because it did have a reference to my program .dll that did have them.
I removed the reference to my program dll from References in the exe, but am now facing more errors that are over my head.
My dll looks like this:
I have written a number of programs in VB.net for AutoCad, but always ran them after loading in an existing AutoCad session.  My company wants to go another route, so I need to be able to do this.  There are no help docs out there that specifically discusss this.
Can you help me out?
Message 18 of 34
mgorecki
I know it says it's passing a string, but I will eventually want to pass an array.  I was just using "string" as it was quick and easy.
Message 19 of 34
Alexander.Rivilis
Hi, Tony!
So it is not only I see that Fenton kidding? Smiley Happy
Expert Elite Member
Message 20 of 34
mgorecki
Hello?  Pointers?  What should I do??  Anything??
