Join using Command
Join using Command
SENL1362
Advisor Advisor
Join using Command
SENL1362
I am kind of stuck getting the JOIN command accepting my selected entities. The error messages are:
Value does not fall within the expected range
From within AutoCAD the selected entities could be JOINed of course.
So what's wrong with the code:
1. Is it the way objects are added to the ed.Command(...);
2. Or has it something to do with the JOIN command itself
Thanks for any help.
These are the trials so far.
       //Goal: Create Polyline from calculated objects using JOIN command
        [CommandMethod("TJC", CommandFlags.UsePickSet | CommandFlags.Modal)]
        public static  async void TestJoinCommand()
            Document doc = null;
            Database db = null;
            Editor ed = null;
            try
                doc = AcadApp.DocumentManager.MdiActiveDocument;
                if (doc == null)
                    throw new System.Exception("No MdiActiveDocument");
                db = doc.Database;
                ed = doc.Editor;
                //ed.Command("_.JOIN", ed.SelectImplied()); //Error: Value does not fall within the expected range
                //ed.Command("_.JOIN", objIds[0], objIds.Skip(1)); //Error: Value does not fall within the expected range
                //PromptSelectionResult selectionRes1 = ed.SelectImplied();
                //ObjectId[] objIds = selectionRes1.Value.GetObjectIds();
                //ed.Command("_.JOIN", objIds[0], objIds[0], objIds[1], objIds[2], "");
                //ed.SetImpliedSelection(new ObjectId[0]);
                //ed.Command("_.JOIN", objIds); //Error: Value does not fall within the expected range
                //ed.SetImpliedSelection(selectionRes1.Value);
                //PromptSelectionResult selectionRes2 = ed.SelectImplied();
                //ed.Command(new object[] { "_.JOIN", selectionRes2 }); //Invalid range
                //ed.Command("_.JOIN", selectionRes1.Value);  //Bad Selection Set
                //await ed.CommandAsync("_.JOIN");
                //using (Transaction tr = db.TransactionManager.StartTransaction())
                //    foreach (ObjectId objId in objIds)
                //        Entity ent = (Entity)tr.GetObject(objId, OpenMode.ForRead);
                //        await ed.CommandAsync(ent.ObjectId);
                //    await ed.CommandAsync("");
                //    tr.Commit();
                //Test1: Send PickSet. Failed
                if (ed.SelectImplied().Value != null)
                    ed.Command("_.JOIN");
                //Test2: Send PickSet, and close selection. Failed
                    ed.Command(new object[]{"_.JOIN", ""});
                    ed.Command("_.JOIN","");
                //Test3: Add objects one at the time. Failed
                SelectionSetDelayMarshalled ssMarshal = (SelectionSetDelayMarshalled)ed.SelectImplied().Value;
                var selObjIds = ssMarshal.GetObjectIds();
                SelectionSet selSet = (SelectionSet)ssMarshal;
                using (DocumentLock docLck = doc.LockDocument())
                     await ed.CommandAsync(selObjIds[0]);
                     for (int i = 1; i < selObjIds.Length; i++)
                         await ed.CommandAsync(selObjIds[i]);
            catch (System.Exception ex)
                if (ed != null)
                    ed.WriteMessage("\n Error in TestJoinCommand: {0}", ex.Message);
_gile
It looks like the "JOIN" command called by Editor.Command() doesn't work exactly the same as the one called from within AutoCAD.
Maybe you'd be more lucky with the "PEDIT" command.
        [CommandMethod("TJC", CommandFlags.Modal | CommandFlags.UsePickSet)]
        public static void TestJoinCommand()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptSelectionResult psr = ed.GetSelection();
            if (psr.Status != PromptStatus.OK)
                return;
            object peditAccept = Application.GetSystemVariable("PEDITACCEPT");
            Application.SetSystemVariable("PEDITACCEPT", 1);
            try
                ed.Command("_.PEDIT", "_Multiple", psr.Value, "", "_Join", 0.0, "");
            catch (Exception ex)
                ed.WriteMessage("\nError: n{0}", ex.Message);
            finally
                Application.SetSystemVariable("PEDITACCEPT", peditAccept);
Gilles Chanteau
GileCAD
GitHub
SENL1362
Hi Gilles,
Thanks for confirming my issues. I hoped the JOIN command could replace the somewhat complicated c# implementation to build polylines from entities.
Also thanks for sending the PEDIT alternative.
_gile
You're welcome.
If you want to implement your own method, you can use or get some inspiration from the GeometryExtension library, mainly the PolylineSegment and PolylineSegmentcollection classes (the second one have an overloaded Join() method).
A using example here.
Gilles Chanteau
GileCAD
GitHub
SENL1362
Thanks for pointing out to that code, I am already using parts of your library.
However in another discussion (i think Kean took part in that) the use of the ed.Command functions where recommended, and thus thought lets try to implement a JOIN function using ed.Command.
Again thanks for you're considerations.
