Iterate Through Raster Images/Image Dictionary
Here's the Code I have so far:
I want to iterate through the Image Dictionary and Connect into the Raster ImageDef Properties.
I want to be able to modify and fix missing Raster Images.
Can someone help me get this code sorted out.
For Each myObjID As ObjectId In myModelSpace
                Dim myEnt As Entity = myObjID.GetObject(OpenMode.ForRead)
If TypeOf myEnt Is Image Then
                        Dim myRasterImg As RasterImage
                        Dim myRasterImgDef As RasterImageDef
                        'Open The Dictionary
                        Dim ImgDict As ObjectId = RasterImageDef.GetImageDictionary(DatabaseIn)
                        For Each dictEntry In ImgDict
                        Next
End If
fieldguy
assuming transaction "avctivetx" is started
For Each dicentry As DBDictionaryEntry In imageDict
            Dim rasterimgDef As RasterImageDef = CType(activetx.GetObject(CType(dicentry.Value, ObjectId), OpenMode.ForRead), RasterImageDef)
            msg = msg & rasterimgDef.ActiveFileName & vbCrLf
        Next
How would I get the RasterImageDef and it's attached properties?
ElseIf TypeOf myEnt Is Image Then
                    Dim myExtImage As New extractRasterImage
                    Dim myRasterImage As RasterImage = CType(myTrans.GetObject(myEnt.ObjectId, OpenMode.ForRead), RasterImage)
                    MsgBox(myRasterImage.Path)
                    myExtImage.Path = myRasterImage.Path
                    myExtractedDB.RasterImages.Add(myExtImage)
If anyone's wondering this is how I got it to work.
   'Start(Transaction)
        Using myTrans As Transaction = DatabaseIn.TransactionManager.StartTransaction
            'Take a Look at Attachments
            Dim nod As DBDictionary
            Dim imageDict As DBDictionary
            nod = CType(myTrans.GetObject(DatabaseIn.NamedObjectsDictionaryId, OpenMode.ForRead, False), DBDictionary)
            imageDict = CType(myTrans.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), OpenMode.ForRead, False), DBDictionary)
            Dim msg As String = ""
                Dim myRasterImgDef As RasterImageDef = CType(myTrans.GetObject(CType(dicentry.Value, ObjectId), OpenMode.ForRead), RasterImageDef)
                msg = (msg & myRasterImgDef.ActiveFileName & vbTab & myRasterImgDef.FileType & vbCr & _
                            vbTab & myRasterImgDef.SourceFileName & vbCrLf)
            Next
            MsgBox(msg)
Never mind...
Found it
                    'Database Image Attachment
                    Dim myRasterImageDef As RasterImageDef = CType(myTrans.GetObject(myRasterImage.ImageDefId, OpenMode.ForRead), RasterImageDef)
                    myExtImage.ActiveFullFileName = myRasterImageDef.ActiveFileName
                    MsgBox(myRasterImage.Path & myRasterImageDef.ActiveFileName)
