Issue when creating an AutoCAD object and ActiveX.
I have code to create an object within a Try block. Specifically an AutoCAD object. What is strange is that sometimes it works and others it throws a Cannot create ActiveX object. What is really peculiar is that it indeed opens AutoCAD (I see in the task manager). It's like there is some kind of delay when establishing the connection and VB can't really cope with this Frankly I am at a total loss.
arcticad
You may need to wait until it's ready to accept the command.
Imports System.Threading
Public Class isQuiescent
    Public Function isQuiescent(ByRef AcadApp As Autodesk.AutoCAD.Interop.AcadApplication) As Boolean
        Try
            While Not AcadApp.GetAcadState.IsQuiescent
                Thread.Sleep(100)
            End While
        Catch ex As Exception
        End Try
        Return True
    End Function
End Class
(defun botsbuildbots() (botsbuildbots))
        Try
            AcadApp = GetObject(, "AutoCAD.Application.18")
            AcadApp = CreateObject("AutoCAD.Application.18")
        End Try
 Where would you call that function? After the CreateObject.
Check out this MS article.  I had the same problem until I implemented this...
http://msdn.microsoft.com/en-us/library/ms228772(VS.80).aspx
Thanks for the info. However, I have no idea how to implement this in the context of my standalone app using VB2010.
Would you be so kind as to provide am details of how you did this.
Scroll down to the bottom of the MS Page and grab the VB code.  Paste it into a class module.
http://msdn.microsoft.com/en-us/library/ms228772(v=vs.80).aspx
Before your code to get or start AutoCAD use this command: "MessageFilter.Register"
Add the end of you start AutoCAD code use this command: "MessageFilter.Revoke"
