IsEMR
IsEMR
IsEMR
I'm trying to test if a dwg is created by Educational version.
This is my code so far
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
namespace ExtractEMR
    public class Commands
        [CommandMethod("EMR")]
        static public void ExtractEMRFromFile()
            Document doc =
              Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            // Ask the user to select a file
            PromptResult res =
              ed.GetString(
                "\nEnter the path of a DWG or DXF file: "
            if (res.Status == PromptStatus.OK)
                // Create a database and try to load the file
                Database db = new Database(false, true);
                using (db)
                    try
                        db.ReadDwgFile(
                          res.StringResult,
                          System.IO.FileShare.Read,
                          false,
                    catch (System.Exception)
                        ed.WriteMessage(
                          "\nUnable to read drawing file."
                        return;
                    Transaction tr =
                      db.TransactionManager.StartTransaction();
                    using (tr)
                        string str = db.IsEMR();
                        ed.WriteMessage(str);
but its saying there is no definition for IsEMR.
OysteinW
IsEMR() is removed from the API in AutoCAD 2015
Try this instead:
object oSerial = Application.GetSystemVariable("_PKSER");
bool IsEducational = oSerial.ToString().StartsWith("900-");
Thanks for your reply,
I'm using ACAD 2013.
I'm trying to get if the drawing is created from Educational, not if using AutoCAD educational.
Thanks again,
I just did it in ARX
Thanks everyone.
