Is there an equivalent to ThisDrawing.PurgeAll in VB.NET?
I'm making some progress in my transition from VBA to VB.NET.  Is there a VB.NET equivalent to VBA's ThisDrawing.PurgeAll?  Or do I need to follow what they are doing here:
http://forums.autodesk.com/t5/NET/Purge-Linetypes/m-p/2899312/highlight/true#M22478
And look for each type of named object (blocks, dim styles, layers, etc...) separately?  I understand that I will also have to iterate until I purge all nested objects.
Constantine
You can use PurgeAll from Autodesk.Autocad.Interop the same as in VBA.
How to find Autodesk.Autocad.Interop? Look at: http://through-the-interface.typepad.com/through_the_interface/2007/02/using_the_com_i.html and http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/files/WS73099cc142f4875...
Other solution (without Interop) you can find here: http://www.theswamp.org/index.php?topic=25880.0
Hi Alexander,
Thanks for the links.  I had tried using the COM version (Autodesk.Autocad.Interop) but it did nothing. I got no error, the statement appeared to run (I placed msgbox statements before and after to make sure that part of the code ran), but nothing was purged.
I will take a closer at "theswamp" link.  I think that is what I was looking for.
Constantine
using System;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
[assembly: CommandClass(typeof(Rivilis.TestMyPurge))]
namespace Rivilis
  class TestMyPurge {
    [CommandMethod("MyPurgeAll")]
    static public void MyPurgeAll()
      AcadDocument doc = AcAp.Application.DocumentManager.MdiActiveDocument.AcadDocument as AcadDocument;
      if (doc != null) {
        doc.PurgeAll();
 Try this sample. Quick testing in AutoCAD 2008 show that this method working as expected.
Hi Alexander,
I copied and pasted into a new C# project and have some difficulties.  I've never used C# before and don't know how to add references to the AutoCAD dll files and to compile to .NET 3.5.
I took a first pass at converting your code to VB.NET, but I'm not very experienced with that version either.  It does not like the line:
If doc <> vbNull Then
Here is my converted code:
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Class Class1
    <Autodesk.AutoCAD.Runtime.CommandMethod("runMyPurge", CommandFlags.Session)> _
    Public Sub MyPurge()
        Dim doc As acaddocument
        doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
            doc.PurgeAll()
        End If
    End Sub
End Class
 Any help is greatly appreciated.
Constantine
I think the equivalent is
If doc IsNot Nothing
-drg
Dan,
Thanks, that works!
Constantine
