Is there a way to define commands in batches?
1039574776
Message 1 of 8
1039574776
Hello everyone, I have an amazing idea🤣. Is it possible to define commands in batches based on a list of block names. Is this possible? Like the code example below, I know, it doesn't work correctly, so would like to try to get help to implement this idea, thanks in advance.
1.
        [CommandMethod("SetCommands")]
        public static void SetCommands()
            List<string> commandList = new List<string>()
                "CMD1",
                "CMD2",
                "CMD3",
                "CMD4",
                "CMD5",
                "CMD6"
            CommandMethods(commandList);
2.
        public static void CommandMethods(List<string> commandList)
            foreach (string globalName in commandList)
                [CommandMethod(globalName)]
                CreateInsertBlockrefence(globalName);
        public static ObjectId CreateInsertBlockrefence(string blockName)
            Document acDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            Editor ed=acDoc.Editor;
            Point3d postion = ed.GetPoint("\nSelect a point:").Value;
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                BlockTable acBlkTbl;
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                if (!acBlkTbl.Has(blockName)) return ObjectId.Null;
                BlockTableRecord acBlkTblRec;
                acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                BlockReference acBlk;
                ObjectId btrId = acBlkTbl[blockName];
                BlockTableRecord record = btrId.GetObject(OpenMode.ForRead) as BlockTableRecord;
                acBlk = new BlockReference(postion, acBlkTbl[blockName]);
                acBlkTblRec.AppendEntity(acBlk);
                acCurDb.TransactionManager.AddNewlyCreatedDBObject(acBlk, true);
                acTrans.Commit();
                return acBlk.ObjectId;
Accepted solutions (3)
Replies (7)
Message 2 of 8
norman.yuan
One surely can "define" command dynamically with code with this method:
Autodesk.AutoCAD.Internal.Utils.AddCommand()
in acmgd.dll
HTH
Norman Yuan
Drive CAD With Code
Message 3 of 8
1039574776
Thanks for your reply, the Autodesk.AutoCAD.Internal.Utils.AddCommand() method is public static void AddCommand(string cmdGroupName, string cmdGlobalName, string cmdLocalName, CommandFlags cmdFlags, CommandCallback func), the fifth parameter method of the method is just a delegate that takes no arguments and returns void.
public delegate void CommandCallback();
so that the command name I define is still not associated with the block name. Is there any other way to achieve this? Meanwhile I'm trying to find other solutions.
Message 4 of 8
kerry_w_brown
Does this help ?
https://forums.autodesk.com/t5/net/utils-addcommand-function-with-params/td-p/4758899
Kerry
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 5 of 8
1039574776
Thanks also, I looked up this link and it wasn't what I was looking for. I want to pass parameters into the method, so that the command name is consistent with the block name, that is, the command name is the block name, so that commands are defined in batches according to all block names.
Message 6 of 8
essam-salah
@1039574776
have you tried to use Autodesk.AutoCAD.Internal.Utils.GetLastCommandLines() ?
Message 7 of 8
1039574776
@essam-salah @norman.yuan Thanks a lot, after debugging ļ¼Œcombined with Autodesk.AutoCAD.Internal.Utils.AddCommand() and Autodesk.AutoCAD.Internal.Utils.GetLastCommandLines(), exactly what I expected, cheers! This link has its usage example code, hope it will be more helpful to others who need it.
https://forums.autodesk.com/t5/net/catching-command-window-output-with-net-api/m-p/9023171
Message 8 of 8
essam-salah
@1039574776 wrote:
@essam-salah @norman.yuan Thanks a lot, after debugging ļ¼Œcombined with Autodesk.AutoCAD.Internal.Utils.AddCommand() and Autodesk.AutoCAD.Internal.Utils.GetLastCommandLines(), exactly what I expected, cheers! ..
glad you your problem solved.
