Is there a .NET property that can be used to identify the AutoCAD vertical?
rhesusminus
Mentor Mentor
rhesusminus
Hi.
I'm about to create some -NET add-ins for AutoCAD Electrical, using the AutoCAD Electrical "API", which is all LISP.
I want to do a check before running any code, to see if AutoCAD Electrical is the version my code is running in.
I've found some LISP-examples for this, but I'd really prefer to use something .NET-ish instead.
So, any ideas?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
_gile
You can get the registry product key using:
HostApplicationServices.Current.MachineRegistryProductRootKey
or:
HostApplicationServices.Current.UserRegistryProductRootKey
And you can have some informations about AutoCAD ProductIds here.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
rhesusminus
Thanks Gilles.
However... Running AutoCAD 2016 from the icon created when installing AutoCAD Electrical 2016, this still reports as AutoCAD Electrical.There's 1 registry key for both 😞
Is there any way to check if a file is loaded maybe? If "acade.mnl" is loaded, we're running AutoCAD Electrical...
Trond Hasse Lie
Ctrl Alt El
moogalm
Autodesk Support
Autodesk Support
I didnt get the problem you are facing, using API userproductregistrykey for Acad electrical you 'll get F007:409 in the string.
F007 is for Acade and F001 is for Acad vanilla.
I don't think there is an API to check if mnl file is loaded.
rhesusminus
When you install AutoCAD Electrical, you will slso get an icon in the start menu, with the option to start AutoCAD Electrical as plain, vanilla AutoCAD.
When I check the registry keys, there is only one there, for AutoCAD Electrical.
So, I will need some other way to find out if it is AutoCAD Electrical that is running.
Trond Hasse Lie
Ctrl Alt El
rhesusminus
This seems to work for AutoCAD Electrical recognition:
 <CommandMethod("CTRLALTEL", "AREWERUNNINGAUTOCADELECTRICAL", "AREWERUNNINGAUTOCADELECTRICAL", CommandFlags.Modal)> _
        Public Sub AreWeRunningAutoCADElecrical()
            If IsThisAutoCADElectrical() Then
                System.Windows.Forms.MessageBox.Show("Yes :)")
            Else
                System.Windows.Forms.MessageBox.Show("No :(")
            End If
        End Sub
        Private Function IsThisAutoCADElectrical() As Boolean
            Try
                Dim Request As New ResultBuffer
                Request.Add(New TypedValue(5005, "ace_getactiveproject"))
                Dim Result As ResultBuffer = Autodesk.AutoCAD.ApplicationServices.Application.Invoke(Request)
                If Not Result Is Nothing Then
                    Return True
                Else
                    Return False
                End If
            Catch Ex As System.Exception
                Return False
            End Try
        End Function
Trond Hasse Lie
Ctrl Alt El
