Is it possible to hide an object?
hericson
Message 1 of 11
hericson
I'm writing my own lengthen dynamically function and I'm using a jig to get the new end point. What I want is to hide the line while using the jig and after getting the new end point from the jig I will unhide the line and change the line's endpoint. Is that possible or do I have to first erase the line and then recreate it after the jig has got the new end point? In that case I have to save all possible properties that I can get from the line so I can apply them to the new line object, it sounds that it's a big chance of missing something.
Replies (10)
Message 2 of 11
Entity.Visible?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6368009@discussion.autodesk.com...
Message 3 of 11
hericson
Sometimes it's too easy. I was looking for something similar but searched for Hide/Unhide, Visible never occur'd to me.
But now I have a new question, look in the code below (it's not complete, I know), how can I make it invisible before calling the jig? If I use acTrans.Commit then I can't continue without errors. Do I have start a new Using?
{code}
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
lin.Visible = False
' call the jig
lin.Visible = True
acTrans.Commit()
End Using
{code}
Message 4 of 11
First, use the Document's TransactionManager, not the
Database's TransactionManager.
See if this works:
{code}
Document doc = ....
using( Transaction tr = doc.TransactionManager.StartTransaction () )
Line line = ....// assign to line to hide
using( Transaction inner = doc.TransactionManager.StartTransaction() )
line.Visible = false;
inner.Commit();
// jig here....
line.Visible = true;
tr.Commit();
{code}
wrote in message news:6368695@discussion.autodesk.com...
Using?
{code}
lin.Visible = False
' call the jig
lin.Visible = True
acTrans.Commit()
End Using
{code}
Message 5 of 11
hericson
No, it didn't work. I even tried a new Line assignment with the inner transaction but no success.
Message 6 of 11
I think you need to enable graphics fllush:
{code}
Document doc = ....
doc.TransactionManager.EnableGraphicsFlush(true);
inner.Commit();
doc.Editor.UpdateScreen();
// jig here....
tr.Commit();
{code}
wrote in message news:6368927@discussion.autodesk.com...
Message 7 of 11
hericson
Still the same...
Message 8 of 11
Where are you calling the code from? A regular command,
A modeless dialog or palette?
wrote in message news:6369577@discussion.autodesk.com...
Still the same...
Message 9 of 11
See the attached example.
Still the same...
Message 10 of 11
hericson
Now it works, thanks! But one conclusion is that you can't nest transactions.
Message 11 of 11
Actually, the hack I posted isn't necessary.
What I overlooked was that it's also necessary to call
the TransactionManager's QueueForGraphicsFlush()
method just before calling FlushGraphics().
With that change you can avoid having to repeatedly
start/commit the outermost transaction.
wrote in message news:6370416@discussion.autodesk.com...
