Is custom .NETCore running application inside AutoCAD or Civil3D?
michael_robertson
michael_robertson
How can I tell if my custom .NET application is running inside plain AutoCAD or Civil 3D?
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
kerry_w_brown
I'm not civil, so I can't test this . .
Crude, but may suit the situation.
Identify a System Variable unique to Civil3D
Check it's value.
Something like :
global using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
global using Exception = System.Exception;
[assembly: CommandClass(typeof(ProductInfoTest.Commands))]
namespace ProductInfoTest
   public class Commands
      [CommandMethod("Test")]
      public static void Test()
         var ed = CadApp.DocumentManager.MdiActiveDocument.Editor;
         try
            //var cmd = (string)CadApp.GetSystemVariable("ACADVER");
            //var cmd = CadApp.GetSystemVariable("UCSICON");
            var cmd = CadApp.GetSystemVariable("PPOINT");
            ed.WriteMessage($"\nVariable .Test : {cmd}\n");
         catch(Exception ex)
            ed.WriteMessage($"\nError: {ex.Message}\n");
"PPOINT" source :
https://www.google.com/search?q=system+variables+unique+to+civil+3d
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
ActivistInvestor
Have you tried checking the PRODUCT system variable?
kerry_w_brown
@ActivistInvestor
Hi Tony,
I wasn't sure about that because you can start "Civil 3D as AutoCAD" using a different profile ( if I remember correctly )
. . . though it makes sense that the "Product" variable would change, so that would be simpler.
