Invoke command in loop by ResultBuffer with Autocad 2015
I have this code: (from here: http://www.acadnetwork.com/index.php?topic=292.0 )
   // Replace "accore.dll" by "acad.exe" for AutoCAD versions prior to 2013
        [System.Security.SuppressUnmanagedCodeSecurity]
        [System.Runtime.InteropServices.DllImport("accore.dll", EntryPoint = "acedCmd", CharSet = System.Runtime.InteropServices.CharSet.Unicode, CallingConvention = System.Runtime.InteropServices.CallingConvention.Cdecl)]
        extern static private int acedCmd(IntPtr resbuf);
        [CommandMethod("offpl")]
        public void cmdOffset()
            ResultBuffer rb = new ResultBuffer();
            // RTSTR = 5005
            rb.Add(new TypedValue(5005, "_.OFFSET"));
            // start the insert command
            acedCmd(rb.UnmanagedObject);
            bool quit = false;
            // loop round while the insert command is active
            while (!quit)
                // see what commands are active
                string cmdNames = (string)Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("CMDNAMES");
                // if the INSERT command is active
                if (cmdNames.ToUpper().IndexOf("OFFSET") >= 0)
                    // then send a PAUSE to the command line
                    // RTSTR = 5005 - send a user pause to the command line
                    rb.Add(new TypedValue(5005, "\\"));
                else
                    // otherwise quit
                    quit = true;
 In AC 2007 it works fine. I've changed acad.exe to accore.dll, but nothing happens.
I'm not getting even "Unknown command".
Can someone help me?
_gile
No more need to P/Invoke acedCmd with AutoCAD 2015.
Have a look at the Editor.Command() and Edtor.CommandAsync() methods.
You may have a look at this thread.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
I will look at this tomorrow. Thanks Smiley Happy
_gile
You can try this way:
    Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
    ed.Command("_.offset");
    while (true)
        try { ed.Command(@"\"); }
        catch { break; }
Gilles Chanteau
GileCAD
GitHub
