Invisible entity in BlockReference
Message 1 of 8
I'm triing to add entities to BlockReference. Entities, that I want to add is not in database (created before in code).
{code}
public static void AddEntityToBR(BlockReference br_Inc, Entity[] are_Inc)
Database db = HostApplicationServices.WorkingDatabase;
Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = db.TransactionManager;
Autodesk.AutoCAD.ApplicationServices.Document dCurrentDock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
ObjectIdCollection oidcAddedEntities = new ObjectIdCollection();
using (Autodesk.AutoCAD.ApplicationServices.DocumentLock DocLock =
dCurrentDock.LockDocument(Autodesk.AutoCAD.ApplicationServices.DocumentLockMode.Write, null, null, true))
using (Transaction trans = tm.StartTransaction())
try
BlockTable bt = (BlockTable)trans.GetObject(dCurrentDock.Database.BlockTableId, OpenMode.ForWrite, true, true);
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
//Add entities to drawing
foreach (Entity eTmp in are_Inc)
oidcAddedEntities.Add(btr.AppendEntity(eTmp));
trans.AddNewlyCreatedDBObject(eTmp, true);
//Open BlockTableRecord and all entities forwrite as Tony Tanzillo said here http://discussion.autodesk.com/forums/thread.jspa?messageID=5700703�
BlockTableRecord btrOfBR = (BlockTableRecord)trans.GetObject(br_Inc.BlockTableRecord, OpenMode.ForWrite);
foreach (ObjectId oidCur in oidcAddedEntities)
DBObject dboTmp = trans.GetObject(oidCur, OpenMode.ForWrite);
btrOfBR.AssumeOwnershipOf(oidcAddedEntities);
trans.Commit();
catch (Exception)
trans.Abort();
throw;
{code}
The code above adds entities to BR (BlockReference), but I don't see them on screen (in the drawing). If I doubleclick on BR in AutoCad (I mean open BlockReference editing mode) and then close BlockReference editing mode with save changes, I can see it in the drawing.
I don't know how to make added entities to be visible in the drawing using C#?
If I call this function
{code}
public static void RegenerateWindow()
Autodesk.AutoCAD.ApplicationServices.Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
object oAcadDoc = doc.AcadDocument;
oAcadDoc.GetType().InvokeMember("Regen", System.Reflection.BindingFlags.InvokeMethod, null, oAcadDoc,
new object[] { 1 });
{code}
added object become visible, but not as member of BR. I mean if i position my cursor on any entity, that belong to BR, whole BR become highlighted. If I position cursor on just added entity, BR do not become highlighted.
Replies (7)
Message 2 of 8
Sorry, the discussion software reformatted your code, and I don't have the
time to format it to be readable.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6266396@discussion.autodesk.com...
{code} public static void AddEntityToBR(BlockReference br_Inc, Entity[]
are_Inc) { Database db = HostApplicationServices.WorkingDatabase;
db.TransactionManager; Autodesk.AutoCAD.ApplicationServices.Document
dCurrentDock =
ObjectIdCollection oidcAddedEntities = new ObjectIdCollection(); using
null, null, true)) { using (Transaction trans = tm.StartTransaction()) { try
{ BlockTable bt =
OpenMode.ForWrite, true, true); BlockTableRecord btr =
OpenMode.ForWrite); //Add entities to drawing foreach (Entity eTmp in
are_Inc) { oidcAddedEntities.Add(btr.AppendEntity(eTmp));
trans.AddNewlyCreatedDBObject(eTmp, true); } //Open BlockTableRecord and all
http://discussion.autodesk.com/forums/thread.jspa?messageID=5700703?
OpenMode.ForWrite); foreach (ObjectId oidCur in oidcAddedEntities) {
DBObject dboTmp = trans.GetObject(oidCur, OpenMode.ForWrite); }
btrOfBR.AssumeOwnershipOf(oidcAddedEntities); trans.Commit(); } catch
(Exception) { trans.Abort(); throw; } } } } {code} The code above adds
I can see it in the drawing. I don't know how to make added entities to be
visible in the drawing using C#? If I call this function {code} public
static void RegenerateWindow() {
object oAcadDoc = doc.AcadDocument; oAcadDoc.GetType().InvokeMember("Regen",
System.Reflection.BindingFlags.InvokeMethod, null, oAcadDoc, new object[]
{ 1 }); } {code} added object become visible, but not as member of BR. I
become highlighted.
Message 3 of 8
Tony, here is post without formatting.
try
trans.Commit();
catch (Exception)
trans.Abort();
throw;
Message 4 of 8
Sorry, what you're trying to do makes no sense.
You're adding new objects to the database, and then
using AssumeOwnershipOf() to transfer them to another
owner block. There is no point in doing that.
Just add the new entities to the block that you want
to be the owner.
Lastly, It's difficult to read code that has identifiers
that are prequalified with the namespace.
wrote in message news:6266398@discussion.autodesk.com...
null, null, true))
try
BlockTable bt =
OpenMode.ForWrite);
Tanzillo said here
OpenMode.ForWrite);
trans.Commit();
catch (Exception)
trans.Abort();
throw;
C#?
Message 5 of 8
I think, that code below is what you advise me to do.
Document dCurrentDock = Application.DocumentManager.MdiActiveDocument;
using (DocumentLock DocLock = dCurrentDock.LockDocument(DocumentLockMode.Write, null, null, true))
try
oidcAddedEntities.Add(btrOfBR.AppendEntity(eTmp));
trans.Commit();
catch (Exception)
trans.Abort();
throw;
But situation didn't changed. Newly added entities is invisible. If only I enter BlockReference edit mode, they become vivsible.
Message 6 of 8
You have to regenerate the block references.
wrote in message news:6266769@discussion.autodesk.com...
Database db = HostApplicationServices.WorkingDatabase; TransactionManager tm
= db.TransactionManager; Document dCurrentDock =
Application.DocumentManager.MdiActiveDocument; ObjectIdCollection
oidcAddedEntities = new ObjectIdCollection(); using (DocumentLock DocLock =
dCurrentDock.LockDocument(DocumentLockMode.Write, null, null, true)) { using
(Transaction trans = tm.StartTransaction()) { try { BlockTableRecord btrOfBR
OpenMode.ForWrite); foreach (Entity eTmp in are_Inc) {
trans.AddNewlyCreatedDBObject(eTmp, true); } trans.Commit(); } catch
Message 7 of 8
Tony, how to regenerate BlockReference?
Message 8 of 8
I have founded solution.
To regenerate BlockReference you have to regenerate layer, where BR is placed.
To regenerate layer watch here http://discussion.autodesk.com/forums/thread.jspa?threadID=467019
