IntersectWith became obsolete in 2012
JanetDavidson
JanetDavidson
Hello everybody.
I had this piece of code in 2010. Now when I re-reference the dll to 2012 . I get a warning message showing:
Public Sub IntersectWith( blah blah blah ) is obsolete. "Use the overload taking IntPrt instead.".  I don't know how . Anybody can help me with this ?
Already appreciated .
Janet,
Here is code.
Dim intpts As New Point3dCollection()
List_Entities(I).IntersectWith(List_Entities(I + 1), Intersect.OnBothOperands, intpts, 0, 0)
chiefbraincloud
I had the same thing come up, and while the "obsolete" version still works for now, it eventually won't.  As it turned out , the function where I had this warning come up was not being used, so my fix has not been tested.
Anyway, seeing that you were just passing zero (as I was) I think you just want to pass New IntPtr(0).
JanetDavidson
Thanks for Reply ,Chief.
What I need is just finding all intersections of objects Not only intpts(0). Is there anything wrong with the Zero I assigned for
thisGraphicSystemMarker  and otherGraphicSystemMarker ?. Is that what you referring to ?
Maybe this will clear my intention better.
                If intpts.Count = 1 Then
                    ' Do this
else
   ' do something else.
end if.
chiefbraincloud
My reply says New IntPtr (0), not intpts(0)...
I mean to pass New IntPtr(0) for the graphics system markers, but like I said, it doesn't give any compile errors, but I have not tested it to make sure that it works as expected.
StephenPreston
Using your code example, changing the function call to this should work:
List_Entities(I).IntersectWith(List_Entities(I + 1), Intersect.OnBothOperands, intpts, IntPtr.Zero, IntPtr.Zero)
Cheers,
Stephen Preston
Autodesk Developer Network
JanetDavidson
Stephen, Thanks. That was the trick.
It is hard for a girl to understand these things.
Janet.
Jozi68
I get the same error with the following code:
For i = 1 To NrV
                            Dim colI As New Point3dCollection
                            Dim colIT As New Point3dCollection
                            myLine.IntersectWith(pollie, Intersect.OnBothOperands, colI, 1, i)
                            myTempLine.IntersectWith(pollie, Intersect.OnBothOperands, colIT, 1, i)
                            If colI.Count > 0 And colIT.Count > 0 Then
                                For j = 0 To colI.Count - 1
                                    colIntersection.Add(colI(j))
                                Next j
                                For j = 0 To colIT.Count - 1
                                    colIntersectionT.Add(colIT(j))
                                Next j
                            End If
                        Next i
 Can someone please help me?
