Interop Excel error
Interop Excel error
Message 1 of 9
Interop Excel error
Hi All,
Please let me know what happen? Error occurred when COM interop Autocad 2012 with excel 2010.
Replies (8)
Message 2 of 9
Alfred.NESWADBA
what code does that message case?
What operating system and what office do you use (e.g. 64bit os ... and so 64bit AutoCAD and maybe 32bit Office)?
And the content of the message (the text under details) might also be necessary, so copy the whole text into a text-file and upload it here.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
Yes. My computer use 64bit AutoCAD 2012-English SP2 and 32bit Excel V14.
This is full detail:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80004023): Retrieving the COM class factory for component with CLSID {00024500-0000-0000-C000-000000000046} failed due to the following error: 80004023 A Microsoft Software Installer error was encountered. (Exception from HRESULT: 0x80004023).
at System.Runtime.Remoting.RemotingServices.AllocateUninitializedObject(RuntimeType objectType)
at System.Runtime.Remoting.Activation.ActivationServices.CreateInstance(RuntimeType serverType)
at System.Runtime.Remoting.Activation.ActivationServices.IsCurrentContextOK(RuntimeType serverType, Object[] props, Boolean bNewObj)
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache)
at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean skipCheckThis, Boolean fillCache)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at Color_tool.Module1.GetExcelData()
at Color_tool.Color_tool.MyCommand.Link_Excel_Copy()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
Message 4 of 9
Alfred.NESWADBA
and what is the code-snippet that brings up that exception?
And have you tried/looked at that: >>>click<<<? (as this is the message within your report)
- alfred -
Alfred NESWADBA
Message 5 of 9
Thanks.
I still don't know how to solve my problem.
Message 6 of 9
Alfred.NESWADBA
Maybe someone is able to do that, but for me: I need to look at the code-snippet to (hopefully) see what's wrong.
Without a code-line knowing what you are doing wrong is quite hard, don't you think so?
- alfred -
Alfred NESWADBA
Message 7 of 9
I'm sorry for misunderstanding your idea.
OK. Attachment is all my code.
Message 8 of 9
Hallex
Try this code, change to your suit before
    '' Working example
Imports System.IO
Imports System.Reflection
Imports System.Runtime.InteropServices
Imports System.Globalization
Imports System.Threading
Imports Microsoft.Office.Interop.Excel
Imports Excel = Microsoft.Office.Interop.Excel
    '' References -> COM -> Microsoft.Excel XX.0 Object Library
    ''' <summary>
    ''' Export one-dimensional array to Excel column
    ''' </summary>
    ''' <param name="sender"></param>
    ''' <param name="e"></param>
    ''' <remarks></remarks>
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        Dim oldCult = CultureInfo.CurrentCulture()
        '' This line is very important!
        Thread.CurrentThread.CurrentCulture = CultureInfo.CreateSpecificCulture("en-US") '<-- change culture on whatever you need
        Dim miss As Object = Type.Missing 'System.Reflection.Missing.Value
        Dim i As Integer
        Dim textfile As String = "C:\Test\MyCodes.txt"
        If (Not File.Exists(textfile)) Then
            MessageBox.Show("File does not exists")
            Return
        End If
        '' Open Excel
        Dim m_objExcel As Excel.Application = New Excel.Application
        m_objExcel.Visible = True
        m_objExcel.UserControl = True
        Dim m_objBooks As Excel.Workbooks = CType(m_objExcel.Workbooks, Excel.Workbooks)
        Dim m_objBook As Excel.Workbook = Nothing
        Try
            '' Open workbook
            m_objBooks.Open("C:\Test\Invoices.xlsx", False, False, miss, "", miss, miss, Excel.XlPlatform.xlWindows, miss, miss, miss, miss, miss, miss, miss)
            m_objBook = m_objExcel.ActiveWorkbook
            m_objBook.Activate() 'optional
            Dim m_objSheets As Sheets = m_objBook.Sheets
            Dim m_objSheet As Worksheet = m_objSheets.Item(1) '<--"Sheet1"
            m_objSheet.Cells.ClearContents() 'optional may to remove this line
            Dim m_objCells As Range = m_objSheet.Cells
            Dim m_objRange As Range = Nothing
            If IO.File.Exists(textfile) Then
                'Create a StreamReader and open our text file
                Using pars As New StreamReader(textfile)
                    i = 1
                    'Now add our columns (we will check to make sure the column doesnt exist before adding it)
                    While Not pars.EndOfStream
                        Dim line As String = pars.ReadLine
                        '' write data starting from cell "A1"
                        m_objRange = m_objSheet.Range(m_objCells(i, 1), m_objCells(i, 1))
                        m_objRange.NumberFormat = "@"
                        m_objRange.Value2 = line
                        i += 1
                    End While
                End Using
            End If
            '' optional just for debug only
            m_objSheet.Range(m_objCells(1, 1), m_objCells(i - 1, 1)).Select()
            m_objRange = m_objSheet.Range(m_objCells(1, 1), m_objCells(i - 1, 1))
            m_objRange.BorderAround(Excel.XlLineStyle.xlContinuous, _
                    Excel.XlBorderWeight.xlMedium, Excel.XlColorIndex.xlColorIndexAutomatic, Excel.XlColorIndex.xlColorIndexAutomatic)
            m_objSheet.Columns.AutoFit()
            '' Save the file in the typical workbook format
            m_objBook.SaveAs("C:\Test\numbers.xlsx", Excel.XlFileFormat.xlWorkbookDefault, "", "", False, False, XlSaveAsAccessMode.xlNoChange, miss, miss, miss, miss, miss)
        Catch ex As System.Exception
            MessageBox.Show(ex.Message & vbCrLf & ex.StackTrace)
        Finally
            '' close workbook and quit Excel
            If Not m_objBook Is Nothing Then
                m_objBook.Close(False, miss, miss)
                m_objBook = Nothing
            End If
            m_objExcel.Quit()
            '' release process if it's still active
            System.Runtime.InteropServices.Marshal.FinalReleaseComObject(m_objExcel)
            Thread.CurrentThread.CurrentCulture = oldCult
        End Try
    End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 9 of 9
Hi Hallex,
All data transfer to excel successfully, however There's a message "Object reference not set to an instance an object.".
Please let me know what happen.
