Insert Dymanic Block from file and changeVisibility States
BrentBurgess1980
BrentBurgess1980
I am trying to insert a Dynamic Block and change it's Visibility State. I can insert the block, and the visibility state changes, however, if I manually try to change it after, it does not change, even though the value has changed. My code executes and returns no errors, so I am assuming that I have done something wrong, or missed something out.
 public class MyCommands
        [CommandMethod("MyGroup", "Bolts", "MyCommandLocal", CommandFlags.Modal)]
        public void MyCommand() // This method can have any name
            InsertBlock(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database, "C:/88NutPlan.dwg", new Point3d(0, 0, 0));
        public static void InsertBlock(Database db, string FileName, Point3d InsertionPoint, double Rotation = 0)
            ObjectId blkid = ObjectId.Null;
            using (Database bdb = new Database(false, true))
                bdb.ReadDwgFile(FileName, System.IO.FileShare.Read, true, "");
                blkid = db.Insert(System.IO.Path.GetFileNameWithoutExtension(FileName), bdb, true);
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord btr = default(BlockTableRecord);
                    btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                    using (btr)
                        BlockReference bref = new BlockReference(InsertionPoint, blkid);
                        using (bref)
                            if (bref.IsDynamicBlock)
                                DynamicBlockReferencePropertyCollection dynBrefColl = bref.DynamicBlockReferencePropertyCollection;
                                foreach (DynamicBlockReferenceProperty dynBrefProps in dynBrefColl)
                                    if (dynBrefProps.PropertyName == "Visibility1")
                                        dynBrefProps.Value = "M36";
                            Matrix3d mat = Matrix3d.Identity;
                            bref.TransformBy(mat);
                            bref.Layer = "0";
                            bref.Rotation = Rotation;
                            btr.AppendEntity(bref);
                            tr.AddNewlyCreatedDBObject(bref, true);
                    tr.Commit();
If I insert my block manually, I can change the states and it works fine, but the code seems to break the block.
Can anyone shed some light on this?
Hallex
You have to change order of your work with block
See if this working for you :
            using (btr)
                             bref.Layer = "0";
                                     if (dynBrefProps.PropertyName.ToUpper() == "VISIBILITY1")
                     tr.Commit();
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
BrentBurgess1980
Thanks Hallex - That worked perfeclty!!
Hallex
You're welcome
Cheers 🙂
~'J'~
