insert block with different name
is there a way to insert a block in the drawing, but with a different name, so it can be edited separately?
I have block A in the drawing and i want to insert it again, but then edit it while the ones already inserted stay unchanged. So i would need it to be inserted as A_1. Is it possible at all?
ok, i solved it, it was actually easier than i thought
all you have to do is change the BlockTableRecord.Name after you insert it in the database
