Insert block from disk
Hi all,
In vb.net I want to insert a block in my dwg.
That block is stored on disk as dwg .
Creating a block that's already loaded isn't a problem (get the block object
id from blocktable and then insert it)
But what if the block isn't in the blocktable and i have to load it from
disk ?
Tnx,
Peter
I hope that this can help
Imports AcDb = Autodesk.AutoCAD.DatabaseServices
Imports AcGe = Autodesk.AutoCAD.Geometry
' Import a block from a external drawing
Shared Function ImportBlock(ByVal FileName As String, _
ByVal blockname As String, _
Optional ByVal silent As Boolean = True) As AcDb.ObjectId
Dim id As AcDb.ObjectId = BlockNameToID(blockname)
If id <> Nothing Then Return id
If Not File.Exists(FileName) Then
If Not silent Then MsgBox("File not found: " & FileName)
Return Nothing
End If
Using db As AcDb.Database = New AcDb.Database
db.ReadDwgFile(FileName, FileShare.ReadWrite, True, "")
Using tr As AcDb.Transaction =
db.TransactionManager.StartTransaction
Using tbl As AcDb.BlockTable =
CType(tr.GetObject(db.BlockTableId, AcDb.OpenMode.ForRead),
AcDb.BlockTable)
If tbl.Has(blockname) Then
id = tbl(blockname)
Dim blk As AcDb.BlockTableRecord = _
CType(db.TransactionManager.GetObject(id,
AcDb.OpenMode.ForRead, False), AcDb.BlockTableRecord)
Dim col As AcDb.ObjectIdCollection = New
AcDb.ObjectIdCollection(New AcDb.ObjectId() {blk.ObjectId})
db.Wblock(AcDb.HostApplicationServices.WorkingDatabase(),
col, New AcGe.Point3d(0, 0, 0), AcDb.DuplicateRecordCloning.Ignore)
tr.Commit()
Else
If Not silent Then MsgBox("Block not found: " &
blockname)
Return Nothing
End If
End Using
End Using
db.CloseInput(True)
End Using
Return BlockNameToID(blockname)
End Function
Shared Function BlockNameToID(ByVal BlockName As String) As
AcDb.ObjectId
Dim tbl As AcDb.BlockTable = GetBlockTableForRead
If tbl.Has(BlockName) Then
Return tbl.Item(BlockName)
End If
Return Nothing
End Function
Shared Function GetBlockTableForRead() As AcDb.BlockTable
Try
Return CType(tr.GetObject(db.BlockTableId,
AcDb.OpenMode.ForRead, False), AcDb.BlockTable)
Catch ex As Exception
End Try
End Using
End Using
Return Nothing
End Function
' Insert an external drawing as a block
Shared Sub InsertDrawing(ByVal dwgName As String, ByVal insPt As
AcGe.Point3d, _
ByVal s3d As AcGe.Scale3d, ByVal rot As Double)
Dim blkName As String = Path.GetFileNameWithoutExtension(dwgName)
Try
Dim id As AcDb.ObjectId = Nothing
Using bt As AcDb.BlockTable =
tr.GetObject(db.BlockTableId, AcDb.OpenMode.ForRead, True)
If Not bt.Has(blkName) Then
Using sourceDb As AcDb.Database = New
AcDb.Database(False, False)
sourceDb.ReadDwgFile(dwgName, FileShare.Read,
True, "")
id = db.Insert(dwgName, sourceDb, False)
tr.GetObject(id, AcDb.OpenMode.ForWrite, False, True)
blk.Name = blkName
End Using
Else
id = bt.Item(blkName)
End If
End Using
Dim btr As AcDb.BlockTableRecord =
tr.GetObject(db.CurrentSpaceId, AcDb.OpenMode.ForWrite, True)
Dim bref As AcDb.BlockReference = New
AcDb.BlockReference(insPt, id)
bref.ScaleFactors = s3d
bref.Rotation = rot
tr.AddNewlyCreatedDBObject(bref, True)
bref.Dispose()
btr.Dispose()
tr.Commit()
MsgBox(ex.ToString)
End Try
End Using
End Using
End Function
tp
I'm protected by SpamBrave
http://www.spambrave.com/
that's it
tnx
"tp" schreef in bericht
news:[email protected]...
Return Nothing
End If
AcDb.BlockTable)
id = tbl(blockname)
tr.Commit()
Else
blockname)
Return Nothing
End If
End Using
End Using
db.CloseInput(True)
End Using
End Function
AcDb.ObjectId
End If
Return Nothing
End Function
Try
End Try
End Using
End Using
Return Nothing
End Function
AcGe.Point3d, _
Try
True, "")
blk.Name = blkName
End Using
Else
End If
End Using
bref.Rotation = rot
bref.Dispose()
btr.Dispose()
tr.Commit()
MsgBox(ex.ToString)
End Try
End Using
End Using
End Function
tp
tp, is there any way i can beg you to comment on the code? I have the need to import a block into an existing drawing from another dwg file. unfortunately i have very little experience and i am not sure how your code works.
thanks
Hi TP
AcGe.Point3d, _
From any module i Can call this Function but please tell me about the passing parameters......
InsertDrawing("C:\sam.dwg",??,??,??)
Please give me any Sample......
Thanks a lot in advance.....
