implement the same function as the command ‘chspace’ problem
swaywood
swaywood
I posted a post a few days ago. Here is the link.
https://forums.autodesk.com/t5/net/how-to-use-code-to-implement-the-same-function-as-the-command/td-...
In most cases, the code in it can achieve the expected effect, but there are also exceptions, such as the dwg I uploaded, the entities did not come to the correct location after executing the command.
swaywood
Sorry, I made a mistake. I changed the order of the two matrix.
The code of link is correct.
//wrong
var WCS2PSDCS1 = vp.WCS2DCS() * vp.DCS2PSDCS();
//correct
var WCS2PSDCS2 = vp.DCS2PSDCS() * vp.WCS2DCS();
_gile
Matrix multiplication is not commutative.
Matrix1 * Matrix2 means: apply Matrix1 to Matrix2.
entity.TransformBy(vp.DCS2PSDCS() * vp.WCS2DCS());
can be written in a sequential way:
entity.TransformBy(vp.WCS2DCS());
entity.TransformBy(vp.DCS2PSDCS());
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
swaywood
Thank you very much. Yes, the second way is easier to understand.
