IGES export
IGES export
IGES export
Is it possible to export IGES files from .NET or lisp?
Regards, Ivo
adam.nagy
Autodesk Support
Autodesk Support
HI there,
Here is a code that may need to be changed depending on which AutoCAD version you are using:
<code>
; Lisp routine for IGESOUT
(defun c:run_igesout()
(setvar "cmddia" 0)
(setvar "filedia" 0)
(arxload "igesout.arx")
(igesout "test.dwg" "")
(arxunload "igesout.arx")
</code>
In AutoCAD 2012 use "AcIges.arx" instead of "igesout.arx" and "igesexport" instead of "igesout"
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
Dear Mr Adam
  Thanks for this lisp routine. I want to auto mate following tasks
1) opening multiple cad files ( lets say 'AA.cad'  to 'FF.cad') which are kept in a specified folder named 'test'
2)open file 'AA.cad'
3)stepout the 3D model contained in cad file. --to the same folder named "test'
4)close the 'AA.cad'.
5) open next cad file and repeat till all cad files are converted.
can you help with this with a lisp routine. we have  one month trial version Autocad16.
