Identify if a block is nested?
js75CAD
js75CAD
I am trying to iterate the block table records of a particular block, but I put this block in my current drawing and both xreferences and nested xreferences contain it.
My code is this, but I am struggling to identify only those blocks directly inserted into model space. I know why it is doing what it is doing, because they all belong in the block table, but how do I stop it from accessing anything that is nested?
    <CommandMethod("UDC_PhaseConnectionReport")> Public Sub UDC_PhaseConnectionReport()
        doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        db = HostApplicationServices.WorkingDatabase
        ed = doc.Editor
        Dim phList As New List(Of Phasedata)
        Try
            Using tr As Transaction = db.TransactionManager.StartTransaction
                Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                If Not bt.Has("phase") Then
                    Return
                Else
                    Dim btr As BlockTableRecord = Nothing
                    Dim btrIDs As ObjectIdCollection = Nothing
                    btr = tr.GetObject(bt("phase"), OpenMode.ForRead)
                    btrIDs = Nothing
                    btrIDs = btr.GetBlockReferenceIds(True, False)
                    ' Go through each phase block and check ju=st like the other one..
                    For Each id As ObjectId In btrIDs
                        If Not id.IsEffectivelyErased Then
                            Dim oBr As BlockReference = TryCast(tr.GetObject(id, OpenMode.ForWrite, False, True), BlockReference)
                            ' Check if it is nested (dependent?)
                            Dim chkbtr As BlockTableRecord = CType(tr.GetObject(oBr.OwnerId, OpenMode.ForWrite), BlockTableRecord)
                            If Not chkbtr.IsDependent Then
                                ' This isn't stopping it...
                                Dim datts As New Dictionary(Of String, String)
                                datts = oBr.GetAttributesValues
                                iPt = oBr.Position
                                Dim strStn As String = "NaN"
                                Dim Sid As String = "NaN"
                                Dim strLot As String = "NaN"
                                Dim strTx As String = "NaN"
                                Dim strPh As String = "NaN"
                                If datts.ContainsKey("STN") Then If Not String.IsNullOrEmpty(datts.Item("STN")) Then strStn = datts.Item("STN")
                                If datts.ContainsKey("ID") Then If Not String.IsNullOrEmpty(datts.Item("ID")) Then Sid = datts.Item("ID")
                                If datts.ContainsKey("LOT") Then If Not String.IsNullOrEmpty(datts.Item("LOT")) Then strLot = datts.Item("LOT")
                                If datts.ContainsKey("TX") Then If Not String.IsNullOrEmpty(datts.Item("TX")) Then strTx = datts.Item("TX")
                                If datts.ContainsKey("P1") Then If Not String.IsNullOrEmpty(datts.Item("P1")) Then strPh = datts.Item("P1")
                                Dim phd As New Phasedata(strLot, strPh, Sid, strStn, strTx)
                                phList.Add(phd)
                    Next
                '' Display the data..
                phList = phList.OrderBy(Function(m) m.lot).ToList
                For Each l In phList
                    ed.WriteMessage(vbLf & "{0} {1}, {2}", l.lot.PadRight(10), l.ph.PadRight(10), l.sID)
                Next
                tr.Commit()
            End Using
        Catch ex As Exception
            MsgBoxWithLineNumber(ex.Message)
        End Try
    End Sub
Is anyone able to please help? I know I could just get all the ones in model space with a editor selection, but I am really trying to learn how to navigate the AutoCAD database and understand the relationship between the block table and its records.
_gile
If I do not misundertand the request, this should work:
        static ObjectIdCollection GetModelSpaceInsertIds(string blockName)
            var db = HostApplicationServices.WorkingDatabase;
            var ids = new ObjectIdCollection();
            using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                var blockTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                if (blockTable.Has(blockName))
                    var modelSpaceId = SymbolUtilityServices.GetBlockModelSpaceId(db);
                    var btr = (BlockTableRecord)tr.GetObject(blockTable[blockName], OpenMode.ForRead);
                    foreach (ObjectId id in btr.GetBlockReferenceIds(true, true))
                        var br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                        if (br.OwnerId == modelSpaceId)
                            ids.Add(id);
                tr.Commit();
            return ids;
Gilles Chanteau
GileCAD
GitHub
