Identify if a block is nested?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to iterate the block table records of a particular block, but I put this block in my current drawing and both xreferences and nested xreferences contain it.
My code is this, but I am struggling to identify only those blocks directly inserted into model space. I know why it is doing what it is doing, because they all belong in the block table, but how do I stop it from accessing anything that is nested?
<CommandMethod("UDC_PhaseConnectionReport")> Public Sub UDC_PhaseConnectionReport()
doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
db = HostApplicationServices.WorkingDatabase
ed = doc.Editor
Dim phList As New List(Of Phasedata)
Try
Using tr As Transaction = db.TransactionManager.StartTransaction
Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
If Not bt.Has("phase") Then
Return
Else
Dim btr As BlockTableRecord = Nothing
Dim btrIDs As ObjectIdCollection = Nothing
btr = tr.GetObject(bt("phase"), OpenMode.ForRead)
btrIDs = Nothing
btrIDs = btr.GetBlockReferenceIds(True, False)
' Go through each phase block and check ju=st like the other one..
For Each id As ObjectId In btrIDs
If Not id.IsEffectivelyErased Then
Dim oBr As BlockReference = TryCast(tr.GetObject(id, OpenMode.ForWrite, False, True), BlockReference)
' Check if it is nested (dependent?)
Dim chkbtr As BlockTableRecord = CType(tr.GetObject(oBr.OwnerId, OpenMode.ForWrite), BlockTableRecord)
If Not chkbtr.IsDependent Then
' This isn't stopping it...
Dim datts As New Dictionary(Of String, String)
datts = oBr.GetAttributesValues
iPt = oBr.Position
Dim strStn As String = "NaN"
Dim Sid As String = "NaN"
Dim strLot As String = "NaN"
Dim strTx As String = "NaN"
Dim strPh As String = "NaN"
If datts.ContainsKey("STN") Then If Not String.IsNullOrEmpty(datts.Item("STN")) Then strStn = datts.Item("STN")
If datts.ContainsKey("ID") Then If Not String.IsNullOrEmpty(datts.Item("ID")) Then Sid = datts.Item("ID")
If datts.ContainsKey("LOT") Then If Not String.IsNullOrEmpty(datts.Item("LOT")) Then strLot = datts.Item("LOT")
If datts.ContainsKey("TX") Then If Not String.IsNullOrEmpty(datts.Item("TX")) Then strTx = datts.Item("TX")
If datts.ContainsKey("P1") Then If Not String.IsNullOrEmpty(datts.Item("P1")) Then strPh = datts.Item("P1")
Dim phd As New Phasedata(strLot, strPh, Sid, strStn, strTx)
phList.Add(phd)
End If
End If
Next
End If
'' Display the data..
phList = phList.OrderBy(Function(m) m.lot).ToList
For Each l In phList
ed.WriteMessage(vbLf & "{0} {1}, {2}", l.lot.PadRight(10), l.ph.PadRight(10), l.sID)
Next
tr.Commit()
End Using
Catch ex As Exception
MsgBoxWithLineNumber(ex.Message)
End Try
End Sub
Is anyone able to please help? I know I could just get all the ones in model space with a editor selection, but I am really trying to learn how to navigate the AutoCAD database and understand the relationship between the block table and its records.
