I choose a center point of a circle but draw it's center in (0,0,0)
almutaz_86
almutaz_86
Good evening .
trying to write a code , drawing a circle after picking the center point ,
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
[assembly: ExtensionApplication(typeof(GetPointTest2.test2))]
namespace GetPointTest2
public class test2:IExtensionApplication
[CommandMethod("test2")]
public void t2()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database dbs = doc.Database;
Editor editr = doc.Editor;
Transaction trans = dbs.TransactionManager.StartTransaction();
ObjectId modspc = dbs.CurrentSpaceId;
BlockTableRecord blkrec = trans.GetObject(modspc, OpenMode.ForWrite) as BlockTableRecord;
try
PromptPointOptions ppo = new PromptPointOptions("\n Pick a point ");
ppo.AllowArbitraryInput = false;
ppo.AllowNone = true;
PromptPointResult ppr1 = editr.GetPoint(ppo);
if (ppr1.Status!=PromptStatus.OK)
return;
ppo.BasePoint = ppr1.Value;
ppo.UseBasePoint = true;
PromptPointResult ppr2 = editr.GetPoint(ppo);
if (ppr2.Status!=PromptStatus.OK)
return;
Point3d cntr = new Point3d(ppo.BasePoint.X, ppo.BasePoint.Y, ppo.BasePoint.Z);
Vector3d vect = new Vector3d();
double rad = 10;
Circle circle = new Circle(cntr, vect, rad);
blkrec.AppendEntity(circle);
trans.AddNewlyCreatedDBObject(circle, true);
catch (Autodesk.AutoCAD.Runtime.Exception excep)
Application.ShowAlertDialog("" + excep );
trans.Commit();
void IExtensionApplication.Initialize()
void IExtensionApplication.Terminate()
thanks 🙂
essam-salah
Hi @almutaz_86
why you ask for 2 points
try this
return;
double rad = 10;
Circle circle = new Circle(ppr1.Value, vect, rad);
_gile
Hi
There are many things in your code that are not very clean or even wrong:
  • you must dispose of the transaction (the simplest way is to wrap it in a using statement)
  • passing a new Vector3d() (i.e., a null vector (0, 0, 0)) to the Circle constructor is certainly the cause of your error
  • you should not commit the transaction outside of the try block
  • you should not write useless code (as for a second point)
  • you should use a separated class to implement IExtensionApplication if you need this (unused here)
[assembly: CommandClass(typeof(GetPointTest2.Test2))]
    public class Test2
        [CommandMethod("TEST2")]
        public static void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var ppr = ed.GetPoint("\n Pick a point ");
            if (ppr.Status != PromptStatus.OK)
                return;
            var center = ppr.Value;
            using (var tr = db.TransactionManager.StartTransaction())
                var circle = new Circle(center, Vector3d.ZAxis, 10.0);
                circle.TransformBy(ed.CurrentUserCoordinateSystem);
                var space = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                space.AppendEntity(circle);
                tr.AddNewlyCreatedDBObject(circle, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
almutaz_86
Thank you @_gile for your important notes, there is some codeblocks I was think its necessary
I'm still in first step of .net api  of AutoCAD
thank you again .
almutaz_86
Thanks @essam-salah
I tried your way, But its not working.
