How to Write it In C#
Message 1 of 13
VBA code:
Dim plineObj As AcadLWPolyline
' Explode the polyline
Dim explodedObjects As Variant
explodedObjects = plineObj.Explode
I want to use C# to write it ,please help me thinks you
Replies (12)
Message 2 of 13
Why not just go to any of the sites on the net
that convert code between C# and VB.NET ?
Or, get a copy of Reflector, and you can view
the compiled code in any of the languages it
supports.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5519449@discussion.autodesk.com...
VBA code:
Message 3 of 13
Could it be because the O.P. wants to know how to convert -- VBA -- to C#?
If there's a VBA to C# converter around I would sure like to know about it.
There is no such thing as a Variant data type in VB.NET so pasting the code
into a VB.NET to C# converter will faill anyway.
For the OP though it might help to explain C# does away with the excess
verbiage such as Dim when initializing. Other verbiage too. The first
statement would be writen as follows... very easy to convert on the fly.
// Object Type Object Name End of statementdelineator
AcadLWPolyline plineObj ;
But as noted, the explodedObjects was initialized in VBA as a Variant data
type which I do not think .NET supports. Using Google to
search msdn2.microsoft.com is where I would go next but if I intended to
learn C# I would go to Deitel & Deitel [1] and get the title of a couple of
their C# "Learn to Program" textbooks. I'd have my local Barnes & Noble
order them all for in-store review and I would buy the one I thought would
help me to learn C#.
<%= Clinton Gallagher
NET csgallagher AT metromilwaukee.com
URL http://clintongallagher.metromilwaukee.com/
[1] http://deitel.com/
"Tony Tanzillo" wrote in message
news:5519512@discussion.autodesk.com...
supports.
VBA code:
Message 4 of 13
Oops.. I thought he meant VB.NET to C#, not VBA to C#.
"clintonG" wrote in message news:5519698@discussion.autodesk.com...
supports.
VBA code:
Message 5 of 13
AcadWLPolyline plineObj=.....;
Object explodedObjects=plineObj.Explode();
Since the returned object is an array of AcadObject, you can then cast it
this way
AcadObject[] objs = (AcadEntity[]) explodedObjects;
Or make code even simple
AcadObject[] objs=plineObj.Explode() As AcadObject[];
VBA code:
Message 6 of 13
think you,I try it, but error
Message 7 of 13
http://discussion.autodesk.com/thread.jspa?threadID=550319
Message 8 of 13
I get it
C# code:
AcadLWPolyline plineObj;
Object[] explodedObjects;
explodedObjects=(Object[])plineObj.Explode();
if((explodedObjects[0] as AcadLine)!=null)
MessageBox.Show(((AcadLine)explodObjects0]).EntityName);
Message 9 of 13
If you want to use C# you have to learn
how to use C# first.
http://msdn.microsoft.com/vstudio/express/beginner/
wrote in message news:5520476@discussion.autodesk.com...
Message 10 of 13
And, you need to be more attentive when reading posts.
Davis
news:5520720@discussion.autodesk.com...
Message 11 of 13
Mosquito, go find a bug light.
"CADJunkie" wrote in message news:5520732@discussion.autodesk.com...
Davis
Message 12 of 13
perhaps a more fundamental question is in order here. if you already know
VBA [perhaps you don't but for arguments sake let's say you do], then why
would you want to switch horses in midstream? unless you're a professional
programmer there is not much to be gained by going to c#. examine your
motivation to choose c#. if it's necessary you may want to consider vb.net.
bob
wrote in message news:5520608@discussion.autodesk.com...
I get it
C# code:
Message 13 of 13
now, you're being too nice.
These super beginner posts are starting to make mine look good!
Tony Tanzillo
|>Davis
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
