how to use selectionset in C#
Message 1 of 15
Hi, I've done this in VB and it worked, but now the same code in C# and it is not working. please help!
basically, I want to select objects using selectionsets.add:
AcadDocument m_ACADDoc;
double []corner1 = new double [3];
double []corner2 = new double [3];
corner1[0] = -100;
corner1[1] = -100;
corner1[2] = 0;
corner2[0] = 100;
corner2[1] = 100;
corner2[2] = 0;
AcadSelectionSet oAcadSSet = m_ACADDoc.SelectionSets.Add("SSET");
object ref_missing = Type.Missing;
oAcadSSet.Select(AcSelect.acSelectionSetCrossing, corner1, corner2, ref_missing, ref_missing);
however, the returned set (oAcadSSet) always contains 0 object.
even if i tried the following (which is copied from internet):
object gpCode = new short[] { 0 };
object dataValue = new object[] { "LINE" };
object groupCode = gpCode;
object DataCode = dataValue;
oAcadSSet.Select(AcSelect.acSelectionSetCrossing, corner1, corner2, groupCode, DataCode);
the set still doesn't contain any object.
Do anyone know how to fix this? thanks!
Replies (14)
Message 2 of 15
Please post code using Rich Text format or an
attached text file.
Joe ...
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
working. please help! basically, I want to select objects using
selectionsets.add: AcadDocument m_ACADDoc; ...... double []corner1 = new
double [3]; double []corner2 = new double [3]; corner1[0] = -100; corner1[1] =
-100; corner1[2] = 0; corner2[0] = 100; corner2[1] = 100; corner2[2] = 0;
AcadSelectionSet oAcadSSet = m_ACADDoc.SelectionSets.Add("SSET"); object
ref_missing = Type.Missing; oAcadSSet.Select(AcSelect.acSelectionSetCrossing,
corner1, corner2, ref_missing, ref_missing); however, the returned set
(oAcadSSet) always contains 0 object. even if i tried the following (which is
copied from internet): object gpCode = new short[] { 0 }; object dataValue =
new object[] { "LINE" }; object groupCode = gpCode; object DataCode =
dataValue; oAcadSSet.Select(AcSelect.acSelectionSetCrossing, corner1, corner2,
groupCode, DataCode); the set still doesn't contain any object. Do anyone know
Message 3 of 15
Is it better now? from my browser, they look the same.
corner1[0] = -100;
corner1[1] = -100;
corner1[2] = 0;
corner2[0] = 100;
corner2[1] = 100;
corner2[2] = 0;
DataCode);
Edited by: YL2000 on Mar 25, 2009 5:09 PM
Message 4 of 15
Did you run your working VB version through a
converter such as the one found in CSharpDevelop
href="http://www.icsharpcode.net/OpenSource/SD/">http://www.icsharpcode.net/OpenSource/SD/
 or
did you hand convert it?
If you didn't use a converter, try that and see
what errors and/or warnings there are and work from there or post your VB
version here or you're welcome to email me directly.
Joe ...
Is
same.
help!
selectionsets.add:
AcadDocument
m_ACADDoc;
double
[3];
corner1[0] = -100;
corner1[1] =
-100;
corner1[2] = 0;
corner2[0] =
100;
corner2[1] = 100;
corner2[2] =
0;
Type.Missing;
corner2,
ref_missing,
ref_missing);
even if i
object
"LINE" };
object
DataCode =
dataValue;
corner1, corner2,
groupCode,
DataCode);
the set still
Do anyone know how
PM
Message 5 of 15
this is the vb code which works well:
Dim pCorner1(0 to 2) as double
Dim pCorner2(0 to 2) as double
pCorner1[0] = 0
pCorner1[1] = 0
pCorner1[2] = 0
pCorner2[0] = 10
pCorner2[1] = 10
pCorner2[2] = 0
Dim ssetObj As AcadSelectionSet
Set ssetObj = ThisDrawing.SelectionSets.Add("SSET")
mode = acSelectionSetCrossing
ssetObj.Select mode, pCorner1, pCorner2
Message 6 of 15
Can't use a converter .... it's regular VB [my
bad].
this
pCorner1[0] =
0
pCorner1[1] = 0
pCorner1[2] = 0
pCorner2[0] =
10
pCorner2[1] = 10
pCorner2[2] = 0
Dim ssetObj As
AcadSelectionSet
Set ssetObj =
mode =
pCorner2
Message 7 of 15
Well, that's not entirely true.
bad].
this
double
pCorner1[0] =
0
pCorner1[1] = 0
pCorner1[2] = 0
pCorner2[0] =
10
pCorner2[1] = 10
pCorner2[2] = 0
Dim ssetObj As
AcadSelectionSet
Set ssetObj =
mode =
pCorner2
Message 8 of 15
Here is a
size=2>VB.NET version. I'll let you convert to C#.
Joe ...
    <CommandMethod("SCW")>
_
    Public Shared Sub
SelectAllCrossingWindowExample()
'get an editor object
        Dim ed As
Editor =
Application.DocumentManager.MdiActiveDocument.Editor
'get the active document
        Dim dwg
As Document = Application.DocumentManager.MdiActiveDocument
        'get a
transaction started
        Using ta As
Transaction = dwg.TransactionManager.StartTransaction
size=2>
Try
Dim LowerLeftPointOptions As PromptPointOptions = New PromptPointOptions("Select
first point of
window")
Dim LowerLeftPointResult As PromptPointResult =
ed.GetPoint(LowerLeftPointOptions)
Dim PromptCornerOptions As PromptCornerOptions = New PromptCornerOptions("Select
opposite point of window",
LowerLeftPointResult.Value)
Dim UpperRightPointResult As PromptPointResult =
ed.GetCorner(PromptCornerOptions)
size=2>
'default select all entities crossed within
window
Dim PromptSelectionResult As PromptSelectionResult =
ed.SelectCrossingWindow(LowerLeftPointResult.Value,
UpperRightPointResult.Value)
size=2>
If (PromptSelectionResult.Status = PromptStatus.OK)
Then
Dim objIDArray() As
ObjectId
'fill an array with the selected
entities
objIDArray = PromptSelectionResult.Value.GetObjectIds()
size=2>
Dim objID As ObjectId
size=2>
For Each objID In
objIDArray
Dim dbObj As
DBObject
'open each entity for
reading
dbObj = ta.GetObject(objID,
OpenMode.ForRead)
'tell user the type of each
entity
ed.WriteMessage(dbObj.GetType.ToString +
vbCrLf)
Next
End If
size=2>            Catch
ex As
Exception
ed.WriteMessage(ex.ToString())
size=2>            End
Try
        End
Using
    End Sub
bad].
this
double
pCorner1[0] =
0
pCorner1[1] = 0
pCorner1[2] = 0
pCorner2[0] =
10
pCorner2[1] = 10
pCorner2[2] = 0
Dim ssetObj
As AcadSelectionSet
Set ssetObj =
mode =
pCorner2
Message 9 of 15
I tried, and it seems the converter doesn't fill out the missing parameters which are required by C# and not required by VB.
Message 10 of 15
Did you use the last code I posted [that's actual
VB.NET code]?
Joe ...
I
Message 11 of 15
yes, i tried that. but it didn't seem to be very helpful.
Message 12 of 15
Make sure your acmgd.dll and acdbmgd.dll "Copy
Local" property is set to False.
Joe ...
using
Autodesk.AutoCAD.ApplicationServices;
using
Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using
Autodesk.AutoCAD.DatabaseServices;
public class
SelectionSetExample
[CommandMethod("SCW")]
    public static void
        //get an editor
object
        Editor ed =
Application.DocumentManager.MdiActiveDocument.Editor;
//get the active document
        Document
dwg = Application.DocumentManager.MdiActiveDocument;
        //get a
transaction started
        using
(Transaction ta =
dwg.TransactionManager.StartTransaction())
size=2>
try
PromptPointOptions LowerLeftPointOptions = new PromptPointOptions("Select first
point of
window");
PromptPointResult LowerLeftPointResult =
ed.GetPoint(LowerLeftPointOptions);
PromptCornerOptions PromptCornerOptions = new PromptCornerOptions("Select
LowerLeftPointResult.Value);
PromptPointResult UpperRightPointResult =
ed.GetCorner(PromptCornerOptions);
size=2>
//default select all entities crossed within
window
PromptSelectionResult PromptSelectionResult =
UpperRightPointResult.Value);
size=2>
if ((PromptSelectionResult.Status ==
PromptStatus.OK))
ObjectId[] objIDArray =
null;
//fill an array with the selected
entities
objIDArray = PromptSelectionResult.Value.GetObjectIds();
size=2>
ObjectId objID = default(ObjectId);
size=2>
foreach (ObjectId objID_loopVariable in
objIDArray)
objID =
objID_loopVariable;
DBObject dbObj =
null;
//open each entity for
reading
OpenMode.ForRead);
//tell user the type of each
entity
ed.WriteMessage(dbObj.GetType().ToString());
size=2>            catch
(System.Exception
ex)
ed.WriteMessage(ex.ToString());
size=2>
yes,
Message 13 of 15
In C#, where you do not want to supply an optional parameter, you supply the
constant 'System.Type.Missing'.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:[email protected]...
Message 14 of 15
Since the SelectCrossingWindow method
is overloaded use the version with just the corner parameters. No need for
optional parameters.
Joe ...
I
Message 15 of 15
Thanks, Tony.
the System.Type.Missing is what I used in my first post. it compiled but the function didn't return any valid objects.
