This seems to work (2D only)
[CommandMethod("PATHARRAY")]
public static void PathArray()
var doc = AcAp.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var ed = doc.Editor;
var selection = ed.GetSelection();
if (selection.Status != PromptStatus.OK)
return;
var entityOptions = new PromptEntityOptions("\nSelect path: ");
entityOptions.SetRejectMessage("\nSelected object is not a valid path.");
entityOptions.AddAllowedClass(typeof(Curve), false);
PromptEntityResult entityResult;
while (true)
entityResult = ed.GetEntity(entityOptions);
if (entityResult.Status != PromptStatus.OK) return;
if (entityResult.ObjectId.ObjectClass.DxfName != "XLINE" &&
entityResult.ObjectId.ObjectClass.DxfName != "RAY")
break;
var kwordOptions = new PromptKeywordOptions("\nChoose a method [Divide/Measure]: ", "Divide Measure");
kwordOptions.AllowNone = true;
kwordOptions.Keywords.Default = "Divide";
var kwordResult = ed.GetKeywords(kwordOptions);
if (kwordResult.Status != PromptStatus.OK)
return;
using (var tr = db.TransactionManager.StartTransaction())
var path = (Curve)tr.GetObject(entityResult.ObjectId, OpenMode.ForRead);
double length = path.GetDistanceAtParameter(path.EndParam);
int nbElements;
double distance;
if (kwordResult.StringResult == "Divide")
var intOptions = new PromptIntegerOptions("\nNumber of elements: ");
intOptions.LowerLimit = 2;
var intResult = ed.GetInteger(intOptions);
if (intResult.Status != PromptStatus.OK)
return;
nbElements = intResult.Value;
distance = length / (nbElements - 1);
else
var distOptions = new PromptDistanceOptions("\nSDistance between elements: ");
distOptions.AllowNegative = false;
distOptions.AllowZero = false;
var distResult = ed.GetDistance(distOptions);
if (distResult.Status != PromptStatus.OK)
return;
distance = distResult.Value;
nbElements = (int)(length / distance) + 1;
var pickedPoint = entityResult.PickedPoint.TransformBy(ed.CurrentUserCoordinateSystem);
var pointOnCurve = path.GetClosestPointTo(pickedPoint, false);
bool fromEnd = length / 2.0 < path.GetDistAtPoint(pointOnCurve);
var origin = fromEnd ? path.EndPoint : path.StartPoint;
double rotation = Vector3d.XAxis.GetAngleTo(path.GetFirstDerivative(origin), Vector3d.ZAxis);
var ids = new ObjectIdCollection(selection.Value.GetObjectIds());
for (int i = 1; i < nbElements; i++)
var point = fromEnd ?
path.GetPointAtDist(length - distance * i) :
path.GetPointAtDist(distance * i);
double angle = Vector3d.XAxis.GetAngleTo(path.GetFirstDerivative(point), Vector3d.ZAxis) - rotation;
var xform =
Matrix3d.Displacement(origin.GetVectorTo(point)) *
Matrix3d.Rotation(angle, Vector3d.ZAxis, origin);
var mapping = new IdMapping();
db.DeepCloneObjects(ids, db.CurrentSpaceId, mapping, false);
foreach (IdPair pair in mapping)
if (pair.IsCloned && pair.IsPrimary)
var entity = (Entity)tr.GetObject(pair.Value, OpenMode.ForWrite);
entity.TransformBy(xform);
tr.Commit();
