How to use a Copy Jig for an Entity Array
Message 1 of 9
I am trying to copy various object type entities. Some entities are lines, circles, block references and polylines. After some time of searching and manipulating code that I found, I was able to find a copy jig for a single entity. My issue is I need it for an array of entities ...
Take a look at the CopyJig class that works for 1 entity (sourcešŸ˜ž
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.DatabaseServices
Imports MgdAcApplication = Autodesk.AutoCAD.ApplicationServices.Application
Imports MgdAcDocument = Autodesk.AutoCAD.ApplicationServices.Document
Imports AcWindowsNS = Autodesk.AutoCAD.Windows
Public Class CopyJig
    Inherits EntityJig
 #Region "Fields"
    Public mCurJigFactorIndex As Integer = 1
    Private mBasePoint As New Point3d()
    Private mNewPoint As Point3d
    ' Factor #1
#End Region
#Region "Constructors"
    Public Sub New(ent As Entity, basePoint As Point3d)
        MyBase.New(ent)
        mNewPoint = InlineAssignHelper(mBasePoint, basePoint.TransformBy(UCS))
    End Sub
#End Region
#Region "Properties"
    Private ReadOnly Property Editor() As Editor
        Get
            Return MgdAcApplication.DocumentManager.MdiActiveDocument.Editor
        End Get
    End Property
    Private ReadOnly Property UCS() As Matrix3d
        Get
            Return Editor.CurrentUserCoordinateSystem
        End Get
    End Property
#End Region
#Region "Overrides"
    Protected Overrides Function Update() As Boolean
        Dim mat As Matrix3d = Matrix3d.Displacement(mBasePoint.GetVectorTo(mNewPoint))
        Entity.TransformBy(mat)
        mBasePoint = mNewPoint
        Return True
    End Function
    Protected Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus
        Select Case mCurJigFactorIndex
            Case 1
                Dim prOptions1 As New JigPromptPointOptions(vbLf & "Location:")
                prOptions1.UserInputControls = UserInputControls.Accept3dCoordinates Or UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect
                prOptions1.BasePoint = mBasePoint
                prOptions1.UseBasePoint = True
                Dim prResult1 As PromptPointResult = prompts.AcquirePoint(prOptions1)
                If prResult1.Status = PromptStatus.Cancel Then
                    Return SamplerStatus.Cancel
                End If
                If prResult1.Value.Equals(mNewPoint) Then
                    'Use better comparision method if wanted.
                    Return SamplerStatus.NoChange
                Else
                    mNewPoint = prResult1.Value
                    Return SamplerStatus.OK
                End If
            Case Else
                Exit Select
        End Select
    End Function
#End Region
#Region "Methods to Call"
    Private Shared Function InlineAssignHelper(Of T)(ByRef target As T, value As T) As T
        target = value
        Return value
    End Function
    Public Shared Function Jig(ent As Entity, basePt As Point3d) As Boolean
        Dim jigger As CopyJig = Nothing
        Try
            jigger = New CopyJig(ent, basePt)
            Dim pr As PromptResult
            Do
                pr = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor.Drag(jigger)
                ' Add keyword handling code below
                If pr.Status = PromptStatus.Keyword Then
                Else
                    jigger.mCurJigFactorIndex += 1
                End If
            Loop While pr.Status <> PromptStatus.Cancel AndAlso pr.Status <> PromptStatus.[Error] AndAlso jigger.mCurJigFactorIndex <= 1
            If pr.Status = PromptStatus.Cancel OrElse pr.Status = PromptStatus.[Error] Then
                If jigger IsNot Nothing AndAlso jigger.Entity IsNot Nothing Then
                    jigger.Entity.Dispose()
                End If
                Return False
            Else
                Return True
            End If
        Catch
            End If
            Return False
        End Try
    End Function
#End Region
End Class
The following class is called using this code:
<CommandMethod("CopyEntities")> _
Public Sub CopyEntities()
    Dim ed As Editor = AcApp.DocumentManager.MdiActiveDocument.Editor
    Dim db As Database = HostApplicationServices.WorkingDatabase
    Dim rb As ResultBuffer
    Dim FoundCorrectXData As Boolean
    Dim Lst_ObjId As New List(Of ObjectId)
    Dim acBlkTbl As BlockTable
    Dim acBlkTblRec As BlockTableRecord
    Dim SelSet As SelectionSet = Nothing
    Dim entities As Entity()
    Try
        Dim selRes As PromptEntityResult = ed.GetEntity(vbLf & "Pick an entity:")
        Dim ptRes As PromptPointResult = ed.GetPoint(vbLf & "Base Point: ")
        If selRes.Status = PromptStatus.OK AndAlso ptRes.Status = PromptStatus.OK Then
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                '------------------------- START BUILDING THE ARRAY OF ENTITIES---------------------
                rb = New ResultBuffer
                rb = selRes.ObjectId.GetObject(OpenMode.ForRead).XData()
                If IsHunter(rb) Then
                    MyObject.SetByDataTable(GetPKFromResultBuffer(rb), Project.PK_Project)
                    acBlkTbl = tr.GetObject(db.BlockTableId, OpenMode.ForRead) 'Open the Block table for read
                    acBlkTblRec = tr.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite) 'Open the Block table record Model space for write
                    'Go through the Block Table Record and build the collection ID
                    For Each acObjId As ObjectId In acBlkTblRec
                        rb = acObjId.GetObject(OpenMode.ForRead).XData()
                        FoundCorrectXData = False
                        If Not rb Is Nothing Then
                            For Each tv As TypedValue In rb
                                If tv.TypeCode = DxfCode.ExtendedDataRegAppName Then
                                    If tv.Value = "OBJECT_TO_BE_FOUND" Then FoundCorrectXData = True
                                End If
                                If FoundCorrectXData And tv.TypeCode = DxfCode.ExtendedDataInteger32 Then
                                    If tv.Value = MyObject.PK_MyObject Then
                                        Lst_ObjId.Add(acObjId)
                                        Exit For
                                    End If
                                End If
                            Next
                            rb.Dispose()
                        End If
                    Next
                    'Create a selection set from the object IDs added to the list
                    SelSet = SelectionSet.FromObjectIds(Lst_ObjId.ToArray)
                    entities = New Entity(SelSet.Count - 1) {}
                    'Create an array of entities
                    For i As Integer = 0 To SelSet.Count - 1
                        entities(i) = DirectCast(tr.GetObject(SelSet(i).ObjectId, OpenMode.ForWrite), Entity)
                    Next
                    '-----------------------------END OF ENTITY ARRAY BUILD----------------------------------
                    'Code used to clone a single entity
                    Dim ent As Entity = TryCast(tr.GetObject(selRes.ObjectId, OpenMode.ForRead), Entity)
                    If ent IsNot Nothing Then
                        Dim clone As Entity = TryCast(ent.Clone(), Entity)
                        If CopyJig.Jig(clone, ptRes.Value) Then
                            Dim ms As BlockTableRecord = TryCast(tr.GetObject(ent.OwnerId, OpenMode.ForWrite), BlockTableRecord)
                            If ms IsNot Nothing Then
                                ms.AppendEntity(clone)
                                tr.AddNewlyCreatedDBObject(clone, True)
                                tr.Commit()
                            End If
                        Else
                            tr.Abort()
                        End If
                    End If
                End If
            End Using
        End If
    Catch ex As System.Exception
        ed.WriteMessage(ex.ToString())
    End Try
End Sub
The goal is to be able to see where I'm copying my entities and be able to select that point. I cleaned up the code above from my CopyEntities method. It includes an array of entities that contain the perfect selection that I wanted. I've been trying to pass this into the CopyJig class but I keep hitting snags.
My main snag is in the constructor of the CopyJig, I cannot pass an array of entities in there...
I thank you for the help in advance,
Alex
Replies (8)
Message 2 of 9
norman.yuan
In most cases of jigging multiple entities, your custom Jig would be better off to derive from DrawJig, rather than EntityJig. However, there is very minor difference between the two in terms the purpose of jigging: providing visual feedback to user's mouse move.
If you insist to use EntityJig, you can simply make your custom jig's constructor like this:
Private myEntities() As Entity
Private myBasePoint As Point3d
Public Sub New MyCopyJig(ents As Entitys(), basePoint As Point3d)
    MyBase(Nothing)
   ''stored the passed entity array in a private member field here
   myEntities=ents
   myBasePoint=basePoint
End Sub
Of course, this EntityJig derived Jib object will have its Entity property equals null, but it will not matter, because you do not need it anyway.
Then in the overriden Update() method, you will transform the array of entities instead of a single entity. Do not forget to dispose the array of cloned entities, if the jiging is cancelled.
Norman Yuan
Drive CAD With Code
Message 3 of 9
Thank you for the feedback norman. After messing around with both DrawJig and EntityJig I decided to go for the DrawJig as you mentioned. I'm almost there! I'll be posting the solution once I get it figured out - or ask for some pointers if I can't get this last bit solved.
Very appreciated.
Message 4 of 9
Here's the new version I started coding that inherits DrawJig. Now, for some reason, it copies the entities correctly but the mLocation (or destination point3d) is not correct. It is set correctly during the sampler but then becomes (0,0,0) once I click on the desired destination. It seems to be copying it over the existing entities that I selected to copy from.
Here's my CopyJig_2.vb class:
Imports AcApp = Autodesk.AutoCAD.ApplicationServices.Application
Public Class CopyJig_2
    Inherits DrawJig
#Region "Fields"
    Private entities As Entity()
    Private mBase As Point3d
    Private mLocation As Point3d
#End Region
    Public Sub New(ents As Entity(), basePt As Point3d)
        entities = ents
        mBase = basePt.TransformBy(UCS)
    End Sub
#End Region
    Public Property Location() As Point3d
        Get
            Return mLocation
        End Get
        Set(value As Point3d)
            mLocation = value
        End Set
    End Property
    Public ReadOnly Property UCS() As Matrix3d
        Get
            Return AcApp.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem
        End Get
    End Property
#End Region
#Region "Methods"
    Public Sub TransformEntities()
        Dim mat As Matrix3d = Matrix3d.Displacement(mBase.GetVectorTo(mLocation))
        Dim line As Line
        Dim pLine As Polyline
        Dim startPoint As Point3d
        Dim endPoint As Point3d
        For Each ent As Entity In entities
            ent.TransformBy(mat)
            'Store main line / polyline for database information
            If ent.Handle.ToString = MyObject.Handle.ToString Then
                If TypeOf ent Is Line Then
                    line = DirectCast(ent, Line)
                    startPoint = line.StartPoint
                    endPoint = line.EndPoint
                ElseIf TypeOf ent Is Polyline Then
                    pLine = DirectCast(ent, Polyline)
                    startPoint = pLine.StartPoint
                    endPoint = pLine.EndPoint
                End If
'Set the primary key to -1 so that it creates another instance of the copied item MyObject.PK_MyObject = -1 MyObject.StartX = startPoint.X MyObject.StartY = startPoint.Y MyObject.EndX = endPoint.X MyObject.EndY = endPoint.Y MyObject.Update() End If Next End Sub Public Function Jig(ents As Entity(), basePt As Point3d) As Boolean Dim jigger As CopyJig_2 = Nothing Try jigger = New CopyJig_2(ents, basePt) Dim pr As PromptResult Do pr = AcApp.DocumentManager.MdiActiveDocument.Editor.Drag(jigger) ' Add keyword handling code below If pr.Status = PromptStatus.Keyword Then Else jigger.mCurJigFactorIndex += 1 End If Loop While pr.Status <> PromptStatus.Cancel AndAlso pr.Status <> PromptStatus.[Error] AndAlso jigger.mCurJigFactorIndex <= 1 If pr.Status = PromptStatus.Cancel OrElse pr.Status = PromptStatus.[Error] Then For Each e As Entity In ents If jigger IsNot Nothing AndAlso e IsNot Nothing Then e.Dispose() End If Next Return False Else Return True End If Catch For Each e As Entity In ents If jigger IsNot Nothing AndAlso e IsNot Nothing Then e.Dispose() End If Next Return False End Try End Function #End Region #Region "Overrides" Protected Overrides Function WorldDraw(draw As Autodesk.AutoCAD.GraphicsInterface.WorldDraw) As Boolean Dim mat As Matrix3d = Matrix3d.Displacement(mBase.GetVectorTo(mLocation)) Dim geo As Autodesk.AutoCAD.GraphicsInterface.WorldGeometry = draw.Geometry If geo IsNot Nothing Then geo.PushModelTransform(mat) For Each ent As Entity In entities geo.Draw(ent) Next geo.PopModelTransform() End If Return True End Function Protected Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus Select Case mCurJigFactorIndex Case 1 Dim prOptions1 As New JigPromptPointOptions(vbLf & "Location:") prOptions1.UserInputControls = UserInputControls.Accept3dCoordinates Or UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect prOptions1.BasePoint = mBase prOptions1.UseBasePoint = True Dim prResult1 As PromptPointResult = prompts.AcquirePoint(prOptions1) If prResult1.Status = PromptStatus.Cancel Then Return SamplerStatus.Cancel End If If prResult1.Value.Equals(mLocation) Then 'Use better comparision method if wanted. Return SamplerStatus.NoChange Else mLocation = prResult1.Value Return SamplerStatus.OK End If Case Else Exit Select End Select Return SamplerStatus.OK End Function #End Region End Class
Here is my command code, I'll shorten it because the majority of it is me filling up the entities array:
Dim cJig As New CopyJig_2(entities, pointResult.Value)
If cJig.Jig(entities, pointResult.Value) Then
    For Each e As Entity In entities
        clone = TryCast(e.Clone, Entity)
        acBlkTblRec.AppendEntity(clone)
        acTrans.AddNewlyCreatedDBObject(clone, True)
    Next
    acTrans.Commit()
Else
    acTrans.Abort()
End If
Any idea why I can't keep the value in mLocation?
Message 5 of 9
_gile
Hi
There's a simpler solution to drag several entities with the overload Editor.Drag(PromptDragOptions) or Editor.Drag(SelectionSet, string, DragCallback) methods. The two methods are similar as the PromptDragOptions constructor requires the same arguments as the second method.
If you're not starting with a selection set, you can build one from an ObjectId array with the static (Shared) SelectionSet.FromObjectIds(ObjectId[]) method.
Here a little example which mimics the MOVE command.
C#
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace CsMoveSelectionSet
    public class Commands
        Point3d _basePoint;
        [CommandMethod("Test")]
        public void Test()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptSelectionResult psr = ed.GetSelection();
            if (psr.Status != PromptStatus.OK)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                List<Entity> ents = new List<Entity>();
                foreach (ObjectId id in psr.Value.GetObjectIds())
                    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
                    ent.Highlight();
                    ents.Add(ent);
                PromptPointOptions ppo = new PromptPointOptions("\nBase point: ");
                ppo.AllowNone = true;
                PromptPointResult ppr = ed.GetPoint(ppo);
                if (ppr.Status != PromptStatus.OK)
                    return;
                Matrix3d ucs = ed.CurrentUserCoordinateSystem;
                Point3d basePoint = ppr.Value.TransformBy(ucs);
                PromptDragOptions pdo = new PromptDragOptions(
                    psr.Value,
                    "\nSecond point: ",
                    delegate(Point3d pt, ref Matrix3d xform)
                        if (pt.IsEqualTo(basePoint))
                            return SamplerStatus.NoChange;
                        else
                            xform = Matrix3d.Displacement(basePoint.GetVectorTo(pt.TransformBy(ucs)));
                            return SamplerStatus.OK;
                pdo.AllowNone = true;
                ppr = ed.Drag(pdo);
                if (ppr.Status == PromptStatus.OK)
                    Matrix3d mat = Matrix3d.Displacement(basePoint.GetVectorTo(ppr.Value.TransformBy(ucs)));
                    foreach (Entity ent in ents)
                        ent.TransformBy(mat);
                else
                        ent.Unhighlight();
                tr.Commit();
F#
module FsMoveSelectionSet
open Autodesk.AutoCAD.ApplicationServices
open Autodesk.AutoCAD.DatabaseServices
open Autodesk.AutoCAD.EditorInput
open Autodesk.AutoCAD.Geometry
open Autodesk.AutoCAD.Runtime
[<CommandMethod("Test")>]
let test () =
    let doc = Application.DocumentManager.MdiActiveDocument
    let db = doc.Database
    let ed = doc.Editor
    let psr = ed.GetSelection()
    if psr.Status = PromptStatus.OK then
        use tr = db.TransactionManager.StartTransaction()
        let ents = psr.Value.GetObjectIds()
                   |> Array.map(fun id ->  tr.GetObject(id, OpenMode.ForWrite) :?> Entity)
        ents |> Array.iter(fun ent -> ent.Highlight())
        let ppo = new PromptPointOptions("\nBase point: ")
        ppo.AllowNone <- true
        let ppr = ed.GetPoint(ppo)
        if ppr.Status = PromptStatus.OK then
            let ucs = ed.CurrentUserCoordinateSystem
            let basePoint = ppr.Value.TransformBy(ucs)
            let pdo = new PromptDragOptions(
                        psr.Value,
                        "\nSecond point: ",
                        fun pt (xform: Matrix3d byref) ->
                            if pt.IsEqualTo(basePoint) then
                            else
                                xform <- Matrix3d.Displacement(basePoint.GetVectorTo(pt.TransformBy(ucs)))
                                SamplerStatus.OK)
            pdo.AllowNone <- true
            let ppr = ed.Drag(pdo)
                let xform = Matrix3d.Displacement(basePoint.GetVectorTo(ppr.Value.TransformBy(ucs)))
                ents |> Array.iter(fun ent -> ent.TransformBy(xform))
            else
                ents |> Array.iter(fun ent -> ent.Unhighlight())
        tr.Commit()
VB
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Namespace VbMoveSelectionSet
    Public Class Commands
        Private basePoint As Point3d
        <CommandMethod("Test")> _
        Public Sub Test()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim psr As PromptSelectionResult = ed.GetSelection()
            If psr.Status <> PromptStatus.OK Then
                Return
            End If
                Dim ents As New List(Of Entity)()
                For Each id As ObjectId In psr.Value.GetObjectIds()
                    Dim ent As Entity = DirectCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
                    ent.Highlight()
                    ents.Add(ent)
                Next
                Dim ppo As New PromptPointOptions(vbLf & "Base point: ")
                ppo.AllowNone = True
                Dim ppr As PromptPointResult = ed.GetPoint(ppo)
                If ppr.Status <> PromptStatus.OK Then
                    Return
                End If
                Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem
                Dim pdo As New PromptDragOptions(psr.Value, vbLf & "Second point: ", AddressOf Callback)
                pdo.AllowNone = True
                ppr = ed.Drag(pdo)
                If ppr.Status = PromptStatus.OK Then
                    Dim mat As Matrix3d = Matrix3d.Displacement(basePoint.GetVectorTo(ppr.Value.TransformBy(ucs)))
                    For Each ent As Entity In ents
                        ent.Unhighlight()
                    Next
                Else
                        ent.Unhighlight()
                    Next
                End If
                tr.Commit()
            End Using
        End Sub
        Private Function Callback(ByVal pt As Point3d, ByRef xform As Matrix3d) As SamplerStatus
            If pt.IsEqualTo(basePoint) Then
            Else
                Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            End If
        End Function
    End Class
End Namespace
Gilles Chanteau
GileCAD
GitHub
Message 6 of 9
_gile
A Copy method using the same way
C#
        private ObjectIdCollection Copy(Database db, Editor ed, ObjectIdCollection source)
            ObjectIdCollection copied = new ObjectIdCollection();
            PromptPointResult result = ed.GetPoint("\nBase point: ");
            if (result.Status != PromptStatus.OK)
                return copied;
            Point3d basePoint = result.Value.TransformBy(ucs);
            using (IdMapping idMap = new IdMapping())
                db.DeepCloneObjects(source, db.CurrentSpaceId, idMap, false);
                foreach (IdPair pair in idMap)
                    if (pair.IsPrimary && pair.IsCloned)
                        copied.Add(pair.Value);
            ObjectId[] ids = new ObjectId[copied.Count];
            copied.CopyTo(ids, 0);
            SelectionSet selSet = SelectionSet.FromObjectIds(ids);
            Matrix3d disp = new Matrix3d();
            DragCallback callback = (Point3d current, ref Matrix3d xform) =>
                    Point3d pt = current.TransformBy(ucs);
                    if (pt.IsEqualTo(basePoint)) return SamplerStatus.NoChange;
                    disp = xform = Matrix3d.Displacement(basePoint.GetVectorTo(pt));
            result = ed.Drag(selSet, "\nSecond point: ", callback);
                var ents = ids.Select(id => (Entity)tr.GetObject(id, OpenMode.ForWrite));
                if (result.Status == PromptStatus.OK)
                        ent.TransformBy(disp);
                else
                        ent.Erase();
                    copied.Clear();
                tr.Commit();
            return copied;
VB
        Private Function Copy(db As Database, ed As Editor, source As ObjectIdCollection) As ObjectIdCollection
            Dim copied As ObjectIdCollection = New ObjectIdCollection()
            Dim result As PromptPointResult = ed.GetPoint(vbLf & "Base point: ")
            If result.Status <> PromptStatus.OK Then
                Return copied
            End If
            Dim basePoint As Point3d = result.Value
            Using idMap As IdMapping = New IdMapping()
                db.DeepCloneObjects(source, db.CurrentSpaceId, idMap, False)
                For Each pair As IdPair In idMap
                    If pair.IsPrimary AndAlso pair.IsCloned Then
                    End If
                Next
            End Using
            Dim ids(copied.Count - 1) As ObjectId
            Dim selSet As SelectionSet = SelectionSet.FromObjectIds(ids)
            Dim disp As Matrix3d = New Matrix3d()
            Dim callback As DragCallback = _
                Function(current As Point3d, ByRef xform As Matrix3d)
                    Dim pt As Point3d = current.TransformBy(ucs)
                    If current.IsEqualTo(basePoint) Then
                    Else
                        disp = xform
                    End If
                End Function
            result = ed.Drag(selSet, vbLf & "Second point: ", callback)
                Dim ents As IEnumerable(Of Entity) = _
                    From id In ids Select DirectCast(tr.GetObject(id, OpenMode.ForWrite), Entity)
                If result.Status = PromptStatus.OK Then
                    Next
                Else
                        ent.Erase()
                    Next
                    copied.Clear()
                End If
                tr.Commit()
            End Using
            Return copied
        End Function
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
_gile
Here's a better implementation of the previous method.
C#
private ObjectIdCollection Copy(Database db, Editor ed, ObjectId[] source)
        return copied;
    SelectionSet selSet = SelectionSet.FromObjectIds(source);
            db.DeepCloneObjects(new ObjectIdCollection(source), db.CurrentSpaceId, idMap, false);
                    Entity ent = (Entity)tr.GetObject(pair.Value, OpenMode.ForWrite);
            tr.Commit();
    return copied;
VB
Private Function Copy(db As Database, ed As Editor, source As ObjectId()) As ObjectIdCollection
        Dim selSet As SelectionSet = SelectionSet.FromObjectIds(source)
                Else
                    disp = xform
                End If
            End Function
                    db.DeepCloneObjects(New ObjectIdCollection(source), db.CurrentSpaceId, idMap, False)
                            Dim ent As Entity = DirectCast(tr.GetObject(pair.Value, OpenMode.ForWrite), Entity)
                        End If
                    Next
                End Using
                tr.Commit()
            End Using
        End If
    End If
Gilles Chanteau
GileCAD
GitHub
Message 8 of 9
_gile
If you rather use a DrawJig derived class, you have to transform the entities (the DrawJig only draws transformed geometries).
C#
the CopyJig class
        class CopyJig : DrawJig
            Point3d basePoint, dragPoint;
            Matrix3d xform;
            Entity[] entities;
            public CopyJig(IEnumerable<Entity> ents, Point3d basePoint)
                this.basePoint = basePoint;
                this.entities = ents.ToArray();
            public Matrix3d Transform { get { return xform; } }
            protected override bool WorldDraw(WorldDraw draw)
                WorldGeometry wg = draw.Geometry;
                xform = Matrix3d.Displacement(basePoint.GetVectorTo(dragPoint));
                wg.PushModelTransform(xform);
                foreach (Entity ent in entities)
                    wg.Draw(ent);
                wg.PopModelTransform();
                return true;
            protected override SamplerStatus Sampler(JigPrompts prompts)
                JigPromptPointOptions options = new JigPromptPointOptions("\nSecond point: ");
                options.BasePoint = basePoint;
                options.UseBasePoint = true;
                options.Cursor = CursorType.RubberBand;
                options.UserInputControls = UserInputControls.Accept3dCoordinates;
                PromptPointResult result = prompts.AcquirePoint(options);
                if (result.Value.IsEqualTo(dragPoint))
                dragPoint = result.Value;
 the JigCopy method
        private ObjectIdCollection JigCopy(Database db, Editor ed, ObjectIdCollection source)
            Entity[] entities = new Entity[source.Count];
                return copied;
                for (int i = 0; i < source.Count; i++)
                    entities[i] = (Entity)tr.GetObject(source[i], OpenMode.ForRead);
                CopyJig jig = new CopyJig(entities, basePoint);
                PromptResult pr = ed.Drag(jig);
                if (pr.Status == PromptStatus.OK)
                    Matrix3d xform = jig.Transform;
                                ent.TransformBy(xform);
                tr.Commit();
            return copied;
VB
the CopyJig class
        Private Class EntitiesJig
            Inherits DrawJig
            Private dragPoint As Point3d
            Private xform As Matrix3d
            Private entities() As Entity
            Public Sub New(ents As IEnumerable(Of Entity), basePt As Point3d)
                basePoint = basePt
            End Sub
            Public ReadOnly Property Transform() As Matrix3d
                Get
                    Return xform
                End Get
            End Property
                Dim options As JigPromptPointOptions = New JigPromptPointOptions(vbLf & "Second point: ")
                options.UseBasePoint = True
                Dim result As PromptPointResult = prompts.AcquirePoint(options)
                If result.Value.IsEqualTo(dragPoint) Then
                End If
            End Function
            Protected Overrides Function WorldDraw(draw As WorldDraw) As Boolean
                Dim wg As WorldGeometry = draw.Geometry
                For Each entity As Entity In entities
                    wg.Draw(entity)
                Next
                Return True
            End Function
        End Class
 the JigCopy method
        Private Function JigCopy(db As Database, ed As Editor, source As ObjectIdCollection) As ObjectIdCollection
            Dim entities(source.Count - 1) As Entity
                Return copied
            End If
            Dim basePoint As Point3d = result.Value.TransformBy(ucs)
                For i = 0 To source.Count - 1
                    entities(i) = DirectCast(tr.GetObject(source(i), OpenMode.ForRead), Entity)
                Next
                Dim jig As EntitiesJig = New EntitiesJig(entities, basePoint)
                Dim pr As PromptResult = ed.Drag(jig)
                If pr.Status = PromptStatus.OK Then
                    Dim xform As Matrix3d = jig.Transform
                                Dim ent As Entity = _
                            End If
                        Next
                    End Using
                End If
                tr.Commit()
            End Using
            Return copied
        End Function
Gilles Chanteau
GileCAD
GitHub
Message 9 of 9
Excellent. It worked great!
Merci!
