How to trim the culve outside the polyline?
swaywood
Message 1 of 17
swaywood
Hi:
I want to imitate the trim command and trim all the curlve outside a closed polyline or a circle.
I found the exactly lisp function but i want to finish it by c#.net, the following is the lisp code and gif pictrue.
https://autocadtips1.com/2012/03/14/trim-and-delete-outside-of-closed-polyline/
best wishes
swaywood
Replies (16)
Message 2 of 17
ActivistInvestor
@swaywood wrote:
Hi:
best wishes
swaywood
Give this a try:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
/// This code requires a reference to AcExportLayoutEx.dll:
using Autodesk.AutoCAD.ExportLayout;
namespace ClipExample
   public static class ClipExampleCommands
      static ObjectId GetClipBoundary(Editor ed)
         var peo = new PromptEntityOptions("\nSelect boundary curve: ");
         peo.SetRejectMessage("\nRequires a closed, planar curve");
         peo.AddAllowedClass(typeof(Curve), false);
         peo.AllowObjectOnLockedLayer = true;
         peo.AllowNone = true;
         var per = ed.GetEntity(peo);
         if(per.Status != PromptStatus.OK)
            return ObjectId.Null;
         using(var tr = new OpenCloseTransaction())
            try
               Curve curve = (Curve) tr.GetObject(per.ObjectId, OpenMode.ForRead);
               if(!(curve.Closed && curve.IsPlanar))
                  ed.WriteMessage("\nInvalid selection, requires a closed, planar curve.");
               return per.ObjectId;
            finally
               tr.Commit();
      static SelectionSet GetObjectsToClip(Editor ed)
         PromptSelectionOptions pso = new PromptSelectionOptions();
         pso.RejectObjectsFromNonCurrentSpace = true;
         pso.RejectObjectsOnLockedLayers = true;
         var filter = new SelectionFilter(
            new[] { new TypedValue(0, "LINE,ARC,CIRCLE,SPLINE,LWPOLYLINE,ELLIPSE") });
         var psr = ed.GetSelection(pso, filter);
         return psr.Status == PromptStatus.OK ? psr.Value : null;
      [CommandMethod("CLIPOBJECTS")]
      public static void ClipObjectsCommand2()
         Document doc = Application.DocumentManager.MdiActiveDocument;
         Editor ed = doc.Editor;
         Database db = doc.Database;
         ObjectId boundaryId = GetClipBoundary(ed);
         if(boundaryId.IsNull)
            return;
         SelectionSet selection = GetObjectsToClip(ed);
         if(selection == null)
            return;
         try
            using(Transaction tr = doc.TransactionManager.StartTransaction())
               Curve boundary = (Curve) tr.GetObject(boundaryId, OpenMode.ForRead);
               var btr = (BlockTableRecord) tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
               foreach(ObjectId id in selection.GetObjectIds())
                  if(id != boundaryId)
                     using(Trimmer trimmer = new Autodesk.AutoCAD.ExportLayout.Trimmer())
                        Entity entityToTrim = (Entity) tr.GetObject(id, OpenMode.ForWrite);
                        trimmer.Trim(entityToTrim, boundary);
                        if(trimmer.HasAccurateResults)
                           foreach(Entity ent in trimmer.TrimResultObjects)
                              ent.SetPropertiesFrom(entityToTrim);
                              btr.AppendEntity(ent);
                              tr.AddNewlyCreatedDBObject(ent, true);
                           if(trimmer.EntityCompletelyOutside || trimmer.EntityOnBoundary)
                              entityToTrim.Erase();
               tr.Commit();
         catch(System.Exception ex)
            ed.WriteMessage("\nOperation failed ({0})", ex.Message);
Message 3 of 17
_gile
@ActivistInvestor Very nice !
Thanks to make me discover this API.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 4 of 17
ActivistInvestor
Thanks @_gile.
Don't forget that as you discovered not long ago, closed, 'heavy', spline-fit polylines will blow up GetSplitCurves() which the Trimmer class uses, so it shouldn't be used on them.
Message 5 of 17
_gile
Thank you for reminding this too.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 17
swaywood
@ActivistInvestor@_gile
thanks for your help.
It would be better if the trimer supports hatch entity.
Work-229.png.
Message 7 of 17
ActivistInvestor
The trimmer doesn't support blocks or hatching. That's supported by EXPORTLAYOUT but it happens at a higher-level in the code, which is more complicated to use because not all of the classes involved are public.
You can write code that explodes the hatching (and block insertions if you need that), and the trimmer will clip the exploded objects. The objects that are to be clipped do not have to be in a database.
Message 8 of 17
I have the same problem ,thanks
Message 9 of 17
you are a nice man ,thanks
Message 10 of 17
😀hi, Great!  I want to ask more, I have read this post: https://autocadtips1.com/2012/03/08/autolisp-trim-objects-on-one-side/
and I tried using the following code but why it didn't work? if typeof TrimEnt is Line then it'll work but it isn't working with Pline,Spline
Dim pick As ResultBuffer = New ResultBuffer()
                        pick.Add(New TypedValue(CShort(LispDataType.ListBegin)))
                        pick.Add(New TypedValue(CShort(LispDataType.ObjectId), TrimEntID))
                        pick.Add(New TypedValue(CShort(LispDataType.Point3d), Pickpt))
                        pick.Add(New TypedValue(CShort(LispDataType.ListEnd)))
   ed.Command("trim", boundset, "", pick, "")
Thanks a lot.
Message 11 of 17
what code must to edit if trim only in inside rectangle
i was try change this if (!trimmer.EntityOnBoundary) but not sucsess
Message 12 of 17
Hi! I'm trying to use the trimmer function in AutoCAD 2021, however I can't find any reference to "Autodesk.AutoCAD.ExportLayout" or AcExportLayoutEx.dll in the documentation. Do you know where I can find info on using these functionalities? Thanks 🙂
Tyler
Message 13 of 17
_gile
You should find it in the AutoCAD installation folder (default: C:\Program Files\Autodesk\AutoCAD 20XX).
Gilles Chanteau
GileCAD
GitHub
Message 14 of 17
kiruba
I had the same requirement, but with a hatch as output. but this helps
Digital Automation in Design Transformation
Message 15 of 17
kiruba
This is amazing. i was searching this for implementing custom shape hatch. Although the result is not a hatch, i can live with it. thanks again
Message 16 of 17
kiruba
This works perfectly. however, i need to clip with nested boundaries. For this i need to clip the entities inside trim boundary. i am unable to achieve this. is there a solution?
Message 17 of 17
Activist_Investor
Well, you could certainly modify the code I posted to perform the inverse operation (remove objects or portions thereof that are within the trim boundary rather than outside of it) and use that modified code with the nested boundary. The original code was never designed to trim against a region with inner loops.
