@Anonymous
In this case you have not define command with CommandMethod attribute, but define with help of Autodesk.AutoCAD.Internal.Utils.AddCommand(string cmdGroupName, string cmdGlobalName, string cmdLocalName, CommandFlags cmdFlags, CommandCallback func) method in your IExtensionApplication.Initialize method only if you condition allowed it.
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Internal;
// This line is not mandatory, but improves loading performances
[assembly: ExtensionApplication(typeof(CommandUtils.MyPlugin))]
namespace CommandUtils
public class MyPlugin : IExtensionApplication
static bool condition = false;
void IExtensionApplication.Initialize()
if (condition)
Utils.AddCommand("RIVILIS", "TEST1", "ТЕСТ1", CommandFlags.Modal, CommandHandler1);
Utils.AddCommand("RIVILIS", "TEST2", "ТЕСТ2", CommandFlags.Modal, CommandHandler2);
void IExtensionApplication.Terminate()
if (condition)
Utils.RemoveCommand("RIVILIS", "TEST1");
Utils.RemoveCommand("RIVILIS", "TEST2");
public void CommandHandler1()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
ed.WriteMessage("\nCommand Test1");
public void CommandHandler2()
ed.WriteMessage("\nCommand Test2");
Facebook | Twitter | LinkedIn
