How to split with intersections between two Polylines ?
anhtrung
Message 1 of 8
anhtrung
Hi everyone,
I have a question that is have two polylines, and it's intersection with together (you can see below image with intersection points 1,2,3,4,5,6). I'm using with C.# to automatic how to split with this intersection can create polylines as right image. File attached to check.
Help me please with using C.# to do that. Thanks.
Replies (7)
Message 2 of 8
_gile
Here's an example which should work on polylines with linear segments.
        [CommandMethod("PLINESPLIT")]
        public static void SplitPolylines()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var options = new PromptEntityOptions("\nSelect first polyline: ");
            options.SetRejectMessage("\nMust be a polyline.");
            options.AddAllowedClass(typeof(Polyline), true);
            var result = ed.GetEntity(options);
            if (result.Status != PromptStatus.OK)
                return;
            var id1 = result.ObjectId;
            options.Message = "\nSelect second polyline: ";
                return;
            var id2 = result.ObjectId;
            using (var tr = db.TransactionManager.StartTransaction())
                var pline1 = (Polyline)tr.GetObject(id1, OpenMode.ForWrite);
                var pline2 = (Polyline)tr.GetObject(id2, OpenMode.ForWrite);
                var plane = new Plane(Point3d.Origin, pline1.Normal);
                var points = new Point3dCollection();
                pline1.IntersectWith(pline2, Intersect.OnBothOperands, points, IntPtr.Zero, IntPtr.Zero);
                AddVertices(pline1, points);
                AddVertices(pline2, points);
                var curveSegments = new DBObjectCollection();
                pline1.Explode(curveSegments);
                pline2.Explode(curveSegments);
                var regions = Region.CreateFromCurves(curveSegments);
                foreach (Entity entity in curveSegments)
                    entity.Dispose();
                var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                foreach (Region region in regions.Cast<Region>().OrderByDescending(r => r.Area).Skip(1))
                    var pline = RegionToPolyline(region);
                    region.Dispose();
                    curSpace.AppendEntity(pline);
                    tr.AddNewlyCreatedDBObject(pline, true);
                pline1.Erase();
                pline2.Erase();
                tr.Commit();
        static void AddVertices(Polyline pline, Point3dCollection points)
            var points3d = points
                    .Cast<Point3d>()
                    .Select(p => pline.GetClosestPointTo(p, false))
                    .Select(p => new { Point = p, Index = (int)Math.Floor(pline.GetParameterAtPoint(p)) })
                    .OrderByDescending(p => p.Index)
                    .ToArray();
            var plane = new Plane(Point3d.Origin, pline.Normal);
            var points2d = points3d.Select(p => p.Point.Convert2d(plane)).ToArray();
            for (int i = 0; i < points3d.Length; i++)
                pline.AddVertexAt(points3d[i].Index + 1, points2d[i], 0.0, 0.0, 0.0);
        static Polyline RegionToPolyline(Region region)
            var normal = region.Normal;
            var plane = new Plane(Point3d.Origin, normal);
            var pline = new Polyline();
            var entitySet = new DBObjectCollection();
            region.Explode(entitySet);
            var edges = entitySet.Cast<Line>().ToList();
            pline.Elevation = edges[0].StartPoint.TransformBy(Matrix3d.WorldToPlane(plane)).Z;
            int i = 0;
            pline.AddVertexAt(i++, edges[0].StartPoint.Convert2d(plane), 0.0, 0.0, 0.0);
            var endPt = edges[0].EndPoint;
            edges.RemoveAt(0);
            while (edges.Count > 0)
                var edge = edges[0];
                if (endPt.IsEqualTo(edge.StartPoint))
                    pline.AddVertexAt(i++, edge.StartPoint.Convert2d(plane), 0.0, 0.0, 0.0);
                    endPt = edge.EndPoint;
                else if (endPt.IsEqualTo(edge.EndPoint))
                    pline.AddVertexAt(i++, edge.EndPoint.Convert2d(plane), 0.0, 0.0, 0.0);
                    endPt = edge.StartPoint;
                else
                    edges.Add(edges[0]);
                edges.RemoveAt(0);
            pline.Closed = true;
            pline.Normal = normal;
            return pline;
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
_gile
This version works with arcs.
        [CommandMethod("SPLITPLINES")]
                return;
                return;
                var curveSegments = SplitPline(pline1, points);
                foreach (DBObject obj in SplitPline(pline2, points))
                    curveSegments.Add(obj);
                    entity.Dispose();
                    region.Dispose();
                pline1.Erase();
                pline2.Erase();
                tr.Commit();
        static DBObjectCollection SplitPline (Polyline pline, Point3dCollection points)
            var pts = new Point3dCollection(
                points
                .Cast<Point3d>()
                .OrderBy(p => pline.GetParameterAtPoint(p))
                .ToArray());
            return pline.GetSplitCurves(pts);
            var edges = entitySet.Cast<Curve>().ToList();
            int i = 0;
            double bulge = 0.0;
            if (edges[0] is Arc)
                bulge = GetBulge((Arc)edges[0], plane);
            pline.AddVertexAt(i++, edges[0].StartPoint.Convert2d(plane), bulge, 0.0, 0.0);
            edges.RemoveAt(0);
                    bulge = 0.0;
                    pline.AddVertexAt(i++, edge.StartPoint.Convert2d(plane), bulge, 0.0, 0.0);
                    bulge = 0.0;
                        bulge = -GetBulge((Arc)edges[0], plane);
                    pline.AddVertexAt(i++, edge.EndPoint.Convert2d(plane), bulge, 0.0, 0.0);
                else
                edges.RemoveAt(0);
            return pline;
        static double GetBulge(Arc arc, Plane plane)
            double bulge;
            double angle = (2.0 * Math.PI + arc.EndAngle - arc.StartAngle) % (2.0 * Math.PI);
            bulge = Math.Tan(angle / 4.0);
            if (arc.Normal.TransformBy(Matrix3d.WorldToPlane(plane)).Z < 0.0)
                bulge = -bulge;
            return bulge;
Gilles Chanteau
GileCAD
GitHub
Message 4 of 8
anhtrung
I have more a question, that is i want to split only at intersect location between two polylines. See image below.
left image have 2 polylines and have 4 intersection, right image is result i want to do that. File attached.
Message 5 of 8
_gile
You should be able to do it on your own by taking inspiration from the above codes.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 8
anhtrung
Thanks Sir, i created success, The first i create polyline with start and end point between segment pline2, and then create region between pline1 with new polyline.
Message 7 of 8
anhtrung
@_gile hi Sir, i have modify code to with situation, but a lot of other situation not work. So help me please write a code to do that, please. Thanks
Message 8 of 8
_gile
Nobody will be able to help you while you do not provide an exhaustive and non-equivoque description of what you want to achieve. You have to define the criterias of your choices in each situation. Despite someones say, there no intelligency in computing, just binary choices: if... then... else...
Gilles Chanteau
GileCAD
GitHub
