CommandEnded SETVAR eventhandler
SRSDS
Advisor Advisor
SRSDS
Is there a way to check which variable is being modified?
_gile
You should try the Application.SystemVariableChanged event.
Gilles Chanteau
GileCAD
GitHub
SRSDS
Ouch. I've probably spent 10 years of my spare time trying to put my app together, and have no idea what you mean by:
How do I implement that?
_gile
Exactly the same as any other event handling, you add an handler to the event.
Application.SystemVariableChanged += Application_SystemVariableChanged;
and, for example:
        private void Application_SystemVariableChanged
            (object sender, Autodesk.AutoCAD.ApplicationServices.SystemVariableChangedEventArgs e)
            if (e.Name == "CLAYER" && e.Changed)
                Application.ShowAlertDialog("Current layer changed")
Gilles Chanteau
GileCAD
GitHub
SRSDS
Gile,
Thanks again,
Wasn't that used to application events but saw I had an OnIdle one.
And the & e.changed in your example is also helpful.
