is that what you are missing?
<Runtime.CommandMethod("ADESK_saveAsDxf")> _ Public Shared Sub ADESK_saveAsDxf() Dim tFileName As String = "C:\TEMP\myDxfFileName.DXF" Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.DxfOut(tFileName, 6, Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current) End Sub
- alfred -
I used this code:
[CommandMethod("DrawingSaved")] public static void DrawingSaved() { Document acDoc = Application.DocumentManager.MdiActiveDocument; Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.DxfOut(acDoc.Name, 6, Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current); }
But it's giving error: Exception was unhandles by user code
eFileAccessErr
if you take acDoc.Name as name for your DXF-file you will recognize, that it will have included the extension ".DWG", but if you want to save it as DXF you should have DXF as extension 😉
<Runtime.CommandMethod("ADESK_saveAsDxf")> _ Public Shared Sub ADESK_saveAsDxf() Dim tAcadDoc As ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim tFileName As String = tAcadDoc.Name If tFileName.ToUpper.EndsWith(".DWG") Then tFileName = Left(tAcadDoc.Name, tAcadDoc.Name.Length - 4) & ".DXF" tAcadDoc.Database.DxfOut(tFileName, 6, Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current) End Sub
HTH, - alfred -
My file was already in the extension. Dxf
🙂 Since yesterday I'm puzzling over it but nothing works 😞
It worked using the command line.
acadDocument.SetVariable("FILEDIA", 0);
acadDocument.SendCommand("SAVE " + FileTxt.FullName + "\nv\n2007\n16\nyes\n");
acadDocument.SetVariable("FILEDIA", 1);
I was creating a dll just to save, so it is better not to have to create a dll.
Ok, the more info, the better we can "debug" 😉
Well the DXFOUT-function exports the current drawing, but it is not to compare with SAVEAS, it's more like WBLOCK. And for WBLOCK you know, that if you are working on a drawing AA.DWG you cannot start WBLOCK and export some elements to AA.DWG ==> you have to take another filename.
And same situation is to use for DXFOUT, you cannot use the same name as you already have opened.
- alfred -
That must be what was wrong then.
Good to know, I'll try!
