How to Retrieve System Configuration in AutoCAD Headless Environment (AccoreConsole)
dev603_tech
dev603_tech
Hi everyone,
We've developed an application that uses AutoCAD in a headless environment (via accoreconsole.exe) to generate drawing PDFs. Occasionally, we've observed that PDF generation takes significantly longer than expected in some instances.
To help identify the root cause, I would like to analyze the system configuration, such as RAM, CPU, disk space, and OS on the environment where accoreconsole is running.
Is there a way to programmatically retrieve system configuration details (e.g., RAM, CPU, OS version, available disk space, etc.) of the AutoCAD headless environment?
Any insights, tools, or guidance on this would be greatly appreciated!
BlackBox_
Core Console supports NETLOAD; load your .NET assembly to perform the desired analysis.
Is your instance of Core Console running on a desktop or the cloud?
If running on a desktop install, this will batch plot your DWGs to PDF via Core Console + the built-in Autopublish mechanism (written in ARX):
https://forums.autodesk.com/t5/net-forum/performance-issues-with-pdf-publishing-multiple-layouts-to/...
HTH
"How we think determines what we do, and what we do determines what we get."
Chris (BlackBox) Bradley
Managing Partner / Developer / Civil Designer
Quux Software | Sincpac C3D | Style Explorer
ActivistInvestor
The OP of this thread is the OP of the thread that you linked to.
daniel_cadext
Recursive
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
BlackBox_
I thought so too, but this was technically a new member, so figured it worth a try. :shrug:
ActivistInvestor
That user posts under many user accounts and routinely creates new ones.
CGBenner
@dev603_tech
Hello, do you still need help with this question?
Chris Benner
