How to restrict block movement along a polyline ?
I need to allow user to place a block with text on top of a polyline. User can place block only along the line not anywhere else.
Kindly let me know if you need any further details.
Alfred.NESWADBA
using parametric/constraints would solve that without any development ...
[video]
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Dear Alfred,
Thank you so much for your response .
But my requirement is to control  block movement programmatically in c#.net.I need  classes or methods in
autocad dotnet api to add the constraints via code.
Raghu.
norman.yuan
Since you are looking for code solution, one of my articles posted quite a while ago might be what you want, or at least gives some idea what/how the code can do:
https://drive-cad-with-code.blogspot.com/2012/03/moving-entity-along-curve.html
Norman Yuan
Drive CAD With Code
