How to recognize a Field in an Attribute Value?
Message 1 of 13
I'm writing code in VB.NET and I've hit a bit of a wall.
I wrote an app which will read from a text file and populate attributes in blocks with the value in the text file.
It works fine; replaces all attribute values correctly with the values in the text file.
But...
I need to have it ignore attributes which already contain a field; as in NOT overwrite attribute values which contain a field.
So...
How do I recognize whether an attribute contains a field?
For each block reference in the drawing I've collected and cycle through Attribute References one-by-one and query the attTag so that I'm updating the correct attribute.  I just need to conditionally state that if the AttRef.attValue contains a field it should be ignored.
How do I do that?
Here's the relevant code:
'See if it has attributes and if one of the attributes is ENTITY_CODE and another is CEID or CE!_CODE
'And collect the Entity Code value
For Each myAttRef As AttRef In GetAttributes(BRefID)
If myAttRef.attTag.ToString = "ENTITY_CODE" Then
myEC = 1
myECValue = myAttRef.attValue.ToString
End If
If myAttRef.attTag.ToString = "CEID" Or myAttRef.attTag.ToString = "CE!_CODE" Then
myCEID = 1
End If
'If myAttRef.Value contains a field then ignore and go on to next
'End If
Next
Thank you for any direction you can offer.
Erik
Replies (12)
Message 2 of 13
Alexander.Rivilis
You can check value of myAttRef.HasFields in order to understand myAttrRef has field(s) or no.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 13
Thank you for the reply.
I found that solution in my many Google searches.  Unfortunately .HasFields isn't available as an option; as in myAttRef.HasFields isn't valid input.  Maybe I'm trying to search that property wrong.  Do I need a special reference to use .HasFields?  I have AcCoreMgd.dll, AcDbMgd.dll and AcMgd.dll loaded as references among some others system references.
The AutoCAD .NET Developer's Guide doesn't make any mention of .HasFields.
That seems to be exactly what I need, but I haven't found a way to make it work.
Suggestions?
Erik
Message 4 of 13
Alexander.Rivilis
AttributeReference class is derived from DBObject class. DBObject class has property HasFields:
 P.S.: What is a class AttRef in your's code? There is no such class in AutoCAD .NET API. Maybe it is a AttributeReference  class?
Expert Elite Member
Message 5 of 13
Alexander.Rivilis
@Anonymous wrote:
...Do I need a special reference to use .HasFields?...
No. You have to reference to AcDbMgd.dll and this enough to use HasFields property.
Expert Elite Member
Message 6 of 13
Alexander.Rivilis
Sample code which check HasFields property and video of using this code:
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
<Assembly: CommandClass(GetType(VBTestHasFields.MyCommands))>
Namespace VBTestHasFields
    Public Class MyCommands
        <CommandMethod("TestFields")> _
        Public Sub MyCommand()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim prOpt As PromptNestedEntityOptions =
                New PromptNestedEntityOptions("Select entity: ")
            Dim prRes As PromptEntityResult = ed.GetNestedEntity(prOpt)
            If prRes.Status = PromptStatus.OK Then
                Dim tr As Transaction = doc.TransactionManager.StartTransaction
                Using (tr)
                    Dim ent As Entity = tr.GetObject(prRes.ObjectId, OpenMode.ForRead)
                    If ent.HasFields Then
                        ed.WriteMessage(vbNewLine + "Entity has fields")
                    Else
                        ed.WriteMessage(vbNewLine + "Entity has NOT fields")
                    End If
                    tr.Commit()
                End Using
            End If
        End Sub
    End Class
End Namespace
Expert Elite Member
Message 7 of 13
Thank you for all the great help.  I really appreciate it.  I'm trying to wrap my head around how to use it...
The code you provided prompts for a block and then queries the block for fields (that's what I interpret)
However, the Attribute Reference is already in focus but is apparently not a database object because the .HasField property isn't an option.
I'll attach a jpg of the code I'm using. It does the following:
- Cycles through each block definition in the drawing
- Cycles through each block reference in each block definition
- For each block reference, it gathers a list of attributes in the block
- For each attribute in the block it gathers some information such as the tag and the value of the attribute.
It is at this point that I need to determine whether the attribute reference currently in focus for the current block reference has a field in its value.
So I'm already drilled down into a specific block reference and specific attribute reference in that block reference.  This is where I need to ask about a field, not at the block reference or higher at the block name level.
I might be getting turned around as to what is a database object and what is not.  I would expect an attribute in a block to be a database object, but maybe not.
I'm attaching a jpg of the relevant portion of the code I'm using because the formatting is visible (as opposed to pasting the code here).  Maybe that's helpful.
I'm so close.  I have the attribute in hand and I just need to ask it if it contains a field.
If I'm not being clear with my inquiry, my apologies.  I'm doing the best I can 🙂
Erik
Message 8 of 13
Alexander.Rivilis
1. Do not post jpg-file of code but post full code.
2. There is no AttRef class in AutoCAD .NET API. What is a AttRef class?
Expert Elite Member
Message 9 of 13
Sorry, I'll paste the code in below.
Regarding the AttRef, it is defined in a Structure contained in the code.  The GetAttributes() function uses the AttRef.
Like a lot of folks, I'm working with code which is pieced together from other apps, gathered from Google searches, with help provided by experts and all done over time by multiple users.  I'm trying to update it's function by having it NOT update attribute values IF the attribute value already contains a field.  If the attribute value contains just text, it updates, but it should leave fields alone.  So, that's my task and what I'm working with.
Here's the code.  I don't know how to paste it into this reply in its own box which preserves its formatting etc.  So here goes:
I'm not pasting in the code from the form.  All it does is prompt the user to browse to and select a drawing for all of this to work on.
Public Sub CEID()
Dim myForm2 As New Form2
Application.ShowModalDialog(myForm2)
myForm2.Close()
Dim ReadPath As String
ReadPath = myForm2.OpenFileDialog2.FileName.ToString
If ReadPath = "OpenFileDialog1" Then
Exit Sub
End If
MsgBox("You chose:" & vbCr & ReadPath & vbCr & "I'll now update CEID attributes...")
Dim myDb As Database = HostApplicationServices.WorkingDatabase
Dim myEd As Editor = DocumentManager.MdiActiveDocument.Editor
Dim myDocument As Document = Application.DocumentManager.MdiActiveDocument
'For each block name in drawing
For Each myBlockName As String In GetTopLevelBlocks(myDb)
'For each instance of each block name in the drawing
For Each BRefID As ObjectId In GetBRefIDs(myDb, myBlockName)
Dim myEC As Integer = 0
Dim myECValue As String = ""
Dim myCEID As Integer = 0
Dim myCEIDValue As String = ""
Dim myField As Integer = 0
If Not myBlockName = "EB" And Not myBlockName = "_DATME" Then
Using myTrans As Transaction = myDocument.TransactionManager.StartTransaction
Dim retList As New List(Of AttRef)
retList = GetAttributes(BRefID)
'Only perform on tool blocks, based on layer assignment A-EQPM-FIXD-*
Dim ent As Entity = CType(myTrans.GetObject(BRefID, OpenMode.ForRead), Entity)
Dim myLayer As String = ent.Layer().ToString
If myLayer.Contains("A-EQPM-FIXD") Then
myEC = 1
End If
myCEID = 1
End If
If myAttRef.HasField = False Then
'Update the attribute value
End If
Next
'If the block has both an Entity Code and a FLEX attribute...
If myEC = 1 And myCEID = 1 Then
'Look for myECValue in the text file and gather the FLEX value
Dim myFSR As New IO.StreamReader(ReadPath)
Using dl As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
While myFSR.EndOfStream = False
Dim txtLine As String = myFSR.ReadLine
Dim txtLineParts() As String = txtLine.Split(",")
If txtLineParts(0) = myECValue Then
System.Windows.Forms.Application.DoEvents()
myEd.WriteMessage(" Updating: " & myECValue & vbCrLf)
myCEIDValue = txtLineParts(1)
For Each myAttRefID In retList
Select Case myAttRefID.attTag.ToUpper
Case "CEID"
UpdateAttributeValue(BRefID, myAttRefID.attTag, myCEIDValue)
Case "CE!_CODE"
End Select
Next
End If
End While
End Using
End If
'If the block has an Entity Code but no FLEX attribute, flag it to the user...
If myEC = 1 And myCEID = 0 Then
MsgBox("This tool: " & myECValue & " has no CEID or CE!_CODE attribute.")
End If
End If
myTrans.Commit()
End Using
End If
Next
Next
'Announce completion
myEd.WriteMessage("Done!")
End Sub
Function GetTopLevelBlocks(ByVal DatabaseIn As Database) As List(Of String)
Dim myList As New List(Of String)
Using myTrans As Transaction = DatabaseIn.TransactionManager.StartTransaction
Dim myBT As BlockTable = DatabaseIn.BlockTableId.GetObject(OpenMode.ForRead)
For Each myBTRid As ObjectId In myBT
Dim myBTR As BlockTableRecord = myBTRid.GetObject(OpenMode.ForRead)
If myBTR.IsAnonymous = False And myBTR.IsLayout = False And _
myBTR.IsFromExternalReference = False And _
myBTR.IsDependent = False Then
myList.Add(myBTR.Name)
End If
Next
End Using
Return myList
End Function
Public Function GetBRefIDs(ByVal DatabaseIn As Database, ByVal BlockName As String) As ObjectIdCollection
Dim retOIDColl As New ObjectIdCollection
If myBT.Has(BlockName) = False Then
Return Nothing
End If
Dim myBTR As BlockTableRecord = myBT(BlockName).GetObject(OpenMode.ForRead)
For Each myObjID As ObjectId In myBTR.GetBlockReferenceIds(True, True)
retOIDColl.Add(myObjID)
Next
Dim another As New ObjectIdCollection
For Each childID As ObjectId In myBTR.GetAnonymousBlockIds
Dim myChildBTR As BlockTableRecord = childID.GetObject(OpenMode.ForRead)
For Each myChildBRefID As ObjectId In myChildBTR.GetBlockReferenceIds(True, True)
retOIDColl.Add(myChildBRefID)
Next
Next
End Using
Return retOIDColl
End Function
Structure AttRef
Dim attTag As String
Dim attValue As String
Dim attHandle As String
End Structure
Function GetAttributes(ByVal BRefID As ObjectId) As List(Of AttRef)
Using myTrans As Transaction = BRefID.Database.TransactionManager.StartTransaction
Dim myBRef As BlockReference = BRefID.GetObject(OpenMode.ForRead)
If myBRef.AttributeCollection Is Nothing Then
Return retList
Else
For Each myAttRefID As ObjectId In myBRef.AttributeCollection
Dim myAttRef As AttributeReference = myAttRefID.GetObject(OpenMode.ForRead)
Dim myRetAttRef As New AttRef
myRetAttRef.attTag = myAttRef.Tag
myRetAttRef.attValue = myAttRef.TextString
myRetAttRef.attHandle = myAttRef.Handle.ToString
retList.Add(myRetAttRef)
Next
End If
End Using
Return retList
End Function
Sub UpdateAttributeValue(ByVal BlockID As ObjectId, ByVal AttributeTag As String, _
ByVal AttributeValue As String)
Using myTrans As Transaction = BlockID.Database.TransactionManager.StartTransaction
Dim myBRef As BlockReference = BlockID.GetObject(OpenMode.ForRead)
Dim myAttCollection As AttributeCollection = myBRef.AttributeCollection
For Each myAttRefID As ObjectId In myAttCollection
Dim myAttRef As AttributeReference = myAttRefID.GetObject(OpenMode.ForWrite)
If myAttRef.Tag.Equals(AttributeTag, StringComparison.OrdinalIgnoreCase) = True Then
myAttRef.TextString = AttributeValue
Exit For
End If
Next
myTrans.Commit()
End Using
End Sub
Message 10 of 13
Alexander.Rivilis
Exactly at this point in yours function GetAttributes you have gather also information about fields in attribute using HasFields property of AttributeReference. Your have to add new member to yours class AttRef with this information.
Expert Elite Member
Message 11 of 13
Alexander.Rivilis
Changed code:
Public Sub CEID()
  myForm2.Close()
    Exit Sub
  End If
            For Each myAttRef As AttRef In retList ' GetAttributes(BRefID)
                myEC = 1
              End If
                myCEID = 1
              End If
              If myAttRef.HasFields = False Then '<------- Changed by Alexander Rivilis
              End If
            Next
                        Case "CEID"
                        Case "CE!_CODE"
                      End Select
                    Next
                  End If
                End While
              End Using
            End If
            End If
          End If
          myTrans.Commit()
        End Using
      End If
    Next
  Next
End Sub
      End If
    Next
  End Using
  Return myList
End Function
      Return Nothing
    End If
    Next
      Next
    Next
  End Using
  Return retOIDColl
End Function
Structure AttRef
  Dim HasFields As Boolean '<------- Added by Alexander Rivilis
End Structure
      myTrans.Commit()
      Return retList
    Else
        myRetAttRef.HasFields = myAttRef.HasFields '<------- Added by Alexander Rivilis
      Next
    End If
  myTrans.Commit() End Using Return retList End Function Sub UpdateAttributeValue(ByVal BlockID As ObjectId, ByVal AttributeTag As String, ByVal AttributeValue As String) Using myTrans As Transaction = BlockID.Database.TransactionManager.StartTransaction Dim myBRef As BlockReference = BlockID.GetObject(OpenMode.ForRead) Dim myAttCollection As AttributeCollection = myBRef.AttributeCollection For Each myAttRefID As ObjectId In myAttCollection Dim myAttRef As AttributeReference = myAttRefID.GetObject(OpenMode.ForWrite) If myAttRef.Tag.Equals(AttributeTag, StringComparison.OrdinalIgnoreCase) = True Then myAttRef.TextString = AttributeValue Exit For End If Next myTrans.Commit() End Using End Sub
P.S.: For inserting code in post use this button:
Expert Elite Member
Message 12 of 13
This looks so promising!  I need to leave for the weekend, but I'll implement Monday and can't wait to see if I can make it work.
Thank you so much.  Have a great weekend.
Erik
Message 13 of 13
This worked perfectly.  What you essentially pointed out to me is that I need to define and ask for the HasFields property back in the Structure and GetAttributes function.  I wish I'd thought of that, and it seems so obvious now that you led me in that direction.
Thank you for taking the time to work with me on this.  I'm learning from you experts every time I embark on a coding project.
With gratitude,
Erik
