How to plot dwg to pdf without AutoCAD running?
 I have a demand to convert a dwg file to a pdf file,but i don't want to install a autocad on my computer.I know that it exsits some way to plot to pdf through ActiveX.And i cant't accept this solution .So ,anyone knows someway to plot dwg to pdf without installing AutoCAD and running AutoCAD?Thanks a lot.
dgorsman
You have to install *something* that reads the DWG file and prints it (unless you're willing to go a cloud route e.g. Forge).  That will either be AutoCAD, or DWG Trueview, or some other application.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
norman.yuan
Besides what @dgorsman has said, you might want to look into Autodesk's Forge cloud services to do that.
Norman Yuan
Drive CAD With Code
