how to open an AutoCAD file update and close with save using C#
kite15
Message 1 of 27
kite15
I am trying to open some AutoCAD file from a Location. After that in the newly opened file added a circle as required. Finally, Close the drawing file with save the newly drawing files.
Actually an error message shown that "Drawing is busy (COMException was caught)".
I have search so many link where discussed about the same. Whereas I am confuse which one the concrete solution for this type of coding.
Here is my Code please help!!
        [CommandMethod("OPSV",CommandFlags.Session)]
        public static void OpenSaveDwgFiles()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            try
                var path = @"C:\TestBack\";
                string dwgFlpath = string.Empty;
                DirectoryInfo d = new DirectoryInfo(path);
                FileInfo[] Files = d.GetFiles("*.dwg");
                //string str = "";
                foreach (FileInfo file in Files)
                    DocumentCollection docMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
                    var fileName = Path.GetFileName(file.FullName);
                    dwgFlpath = path+fileName;
                    DocumentCollectionExtension.Open(docMgr, dwgFlpath,false);
                    using (DocumentLock LckDoc = doc.LockDocument())
                        using (Transaction tr = db.TransactionManager.StartTransaction())
                            BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                            BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                            using (Circle crcl = new Circle())
                                crcl.Center = new Point3d(1, 1, 0);
                                crcl.Radius = 2;
                                btr.AppendEntity(crcl);
                                tr.AddNewlyCreatedDBObject(crcl, true);
                            tr.Commit();
                    //doc.CloseAndDiscard();
                    doc.CloseAndSave(dwgFlpath.Substring(0,dwgFlpath.Length-4));
            catch (System.Exception ex)
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString());
Replies (26)
Message 21 of 27
SanjoyNath
Dear Experts,
We dont know why even after so many years they are not giving record c sharp macro , record other(vbs or scr ) macros as .cs files or .vbs files
Note
the Activity recorder is dumb concept now. People are habituated to create scripts on their mobiles and on social networking. They expect these (record csharp macros) as most fundamental requirement as command line. Word, Excel , powerpoint has made users too much greedy for these features        (Please understand)
Sanjoy Nath
BIM Manager And Digital Lead (Structures Online)
BOOST, AR , VR ,EPM,IFC API,PDF API , CAD API ,Revit API , Advance Steel API
Founder of Geometrifying Trigonometry(C)
Message 22 of 27
k005
Hello there
Can preview be included in this code?
How can we add these codes?
Thanks.
Document doc = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
Database db = Application.DocumentManager.MdiActiveDocument.Database;
db.ThumbnailBitmap = doc.CapturePreviewImage(320, 240);
Message 23 of 27
k005
@_gile
Message 3 of 22
//Document doc = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
//Database db = Application.DocumentManager.MdiActiveDocument.Database;
//db.ThumbnailBitmap = doc.CapturePreviewImage(320, 240);
Message 24 of 27
k005
@_gile
Message 3 of 22
Message 25 of 27
khugt60
Hi Sir
I want to change the input (Link) that's the input from the user.
What's the class or Method for this?
Thank you!
Message 26 of 27
Alexander.Rivilis
@khugt60 wrote:
Hi Sir
Thank you!
For example, Editor.GetString()
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 27 of 27
Alexander.Rivilis
Also read this article: https://www.keanw.com/2009/08/allowing-a-user-to-select-from-multiple-file-formats-inside-autocad-us...
Expert Elite Member
