How to make two polylines eachother.
MarkJamesRogolino
Message 1 of 24
MarkJamesRogolino
Hello, everyone. Now I have to make two polylines (these are separated each other) touch.Is there a way to implement this process
Replies (23)
Message 21 of 24
kerry_w_brown
@MarkJamesRogolino
The partial code you posted is of no use to me for resolving your issue.
At first glance it seems adequate.
What is the difference between the moved location and your expected location ?
I did test the original version of IsPointOnPolyline ( similar to the one you used )
// (C) CodeHimBelonga: kdub 2023/03/03
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using System;
using System.Runtime.CompilerServices;
//using Kdub.Common;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
[assembly: CommandClass(typeof(TouchingPolylines.TestCommands_02))]
namespace TouchingPolylines
   public class TestCommands_02
      private static Document _doc => AcadApp.DocumentManager.MdiActiveDocument;
      private static Database _db => _doc.Database;
      private static Editor _ed => _doc.Editor;
      public static void WriteMessage(string msg) => _ed.WriteMessage(msg);
      [CommandMethod("plSegment")]
      public static void PlineSegment()
         PromptEntityOptions peo = new PromptEntityOptions("\nSelect a Polyline Segment: ");
         peo.SetRejectMessage("\nMust be a Polyline...");
         peo.AddAllowedClass(typeof(Polyline), true);
         PromptEntityResult per = _ed.GetEntity(peo);
         if (per.Status == PromptStatus.Cancel) return;
         using (Transaction tr = _doc.TransactionManager.StartTransaction())
            var pline = (Polyline)per.ObjectId.GetObject(OpenMode.ForRead);
            var wcsPickedPoint = per.PickedPoint.TransformBy(_ed.CurrentUserCoordinateSystem);
            var wcspointOnPline = pline.GetClosestPointTo(wcsPickedPoint, false);
            var segmentIndex = (int)pline.GetParameterAtPoint(wcspointOnPline);
            if (pline.GetSegmentType(segmentIndex) == SegmentType.Line)
               _ed.WriteMessage("\n--------------------------------\n");
               LineSegment2d segment = pline.GetLineSegment2dAt(segmentIndex);
               _ed.WriteMessage($"segmentIndex: {segmentIndex}\n");
               _ed.WriteMessage($"segment Length: {segment.Length}\n");
               _ed.WriteMessage($"Angle: {( segment.Direction.Angle * 180 / Math.PI )}°\n");
               _ed.WriteMessage($"Start-WCS: {segment.StartPoint} , End-WCS: {segment.EndPoint}\n");
               _ed.WriteMessage($"per.PickedPoint(ucs): {per.PickedPoint}\n");
               _ed.WriteMessage($"Pline_Vertex2D(wcs): {pline.GetPoint2dAt(segmentIndex)} , 3D: {pline.GetPoint3dAt(segmentIndex)}\n");
            else
               _ed.WriteMessage($"\nsegment Type: {pline.GetSegmentType(segmentIndex)}\n");
            tr.Commit();
            bool isOn = IsPointOnPolyline(pline, wcspointOnPline);
            _ed.WriteMessage($"IsPointOnPolyline: {isOn}\n");
      public static bool IsPointOnPolyline(Polyline pl, Point3d pt)           // this returns point is on polyline or not.
         bool isOn = false;
         for (int i = 0; i < pl.NumberOfVertices; i++)
            Curve3d seg = null;
            SegmentType segType = pl.GetSegmentType(i);
            if (segType == SegmentType.Arc)
               seg = pl.GetArcSegmentAt(i);
            else if (segType == SegmentType.Line)
               seg = pl.GetLineSegmentAt(i);
            if (seg != null)
               isOn = seg.IsOn(pt);
               if (isOn)
                  break;
         return isOn;
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 22 of 24
kerry_w_brown
In Fact, all versions test OK.
            _ed.WriteMessage($"IsPointOnPolyline: {IsPointOnPolyline(pline, wcspointOnPline)}\n");
            _ed.WriteMessage($"IsPointOnCurveGDAP: {IsPointOnCurveGDAP((Curve)pline, wcspointOnPline)}\n");
            _ed.WriteMessage($"IsPointOnCurveGCP: {IsPointOnCurveGCP((Curve)pline, wcspointOnPline)}\n");
      // A generalized IsPointOnCurve function that works on all
      // types of Curve (including PolyLines), but catches an
      // Exception on failure
      public static bool IsPointOnCurveGDAP(Curve cv, Point3d pt)
         try
         {            // Return true if operation succeeds
            cv.GetDistAtPoint(pt);
            return true;
         catch { }
         // Otherwise we return false
         return false;
      // types of Curve (including PolyLines), and checks the position
      // of the returned point rather than relying on catching an
      // exception
      public static bool IsPointOnCurveGCP(Curve cv, Point3d pt)
         try
            Point3d p = cv.GetClosestPointTo(pt, false);
            return ( p - pt ).Length <= Tolerance.Global.EqualPoint;
         catch { }
         return false;
         bool isOn = false;
            Curve3d seg = null;
            if (seg != null)
               if (isOn)
                  break;
         return isOn;
From this I'd conclude that the fault is with your "Moving" code, not with these methods.
Message 23 of 24
kerry_w_brown
Perhaps this will help
https://www.theswamp.org/index.php?topic=58137.msg613490#msg613490
Message 24 of 24
kerry_w_brown
Any joy Vladimir ??
