VB | can't figure out ^C^C in command handler
snappyjazz
snappyjazz
Hello. I can't figure out how to clear before my command using the command handler. The command line always says it doesn't recognize my command. I've tried:
 RibBtn.CommandParameter = "^C^CCommandName"
RibBtn.CommandParameter = "^C^C CommandName"
RibBtn.CommandParameter = "CommandName"  the following use this same parameter
Doc.SendStringToExecute(Chr(94) & "C" & Chr(94) & "C" RibBtn.CommandParameter & " ", True, False, False)
Doc.SendStringToExecute("^C^C" & RibBtn.CommandParameter & " ", True, False, False)
It does work though if I call just the command name. It feels weird not clearing before calling a command. Any ideas?
Jeff_M
Even though this post is in c# you should be able to see what you need to do:
https://adndevblog.typepad.com/autocad/2012/07/start-command-with-escape-characters-cc.html
Another good reason to code in c# vs VB...lots more examples available.
Jeff_M, also a frequent Swamper
snappyjazz
Thank you. Everything makes sense except the character /x03. Where after googling is a ASCII character; which is different than Chr() characters(See screen shot). I cannot find documentation on how to use ASCII characters in vb.net yet. Do you know off the top of your head?
norman.yuan
It is not "/x03", but "\x03".
Norman Yuan
Drive CAD With Code
snappyjazz
@norman.yuan Thanks for catching that. However I still don't know how to use it and get the ^C like here. A snapshot of my ignorance.
norman.yuan
Something like (run command "_.Line", for example):
Doc.SendStringToExecute("\x03\x03_.LINE ", True, False, False)
Norman Yuan
Drive CAD With Code
snappyjazz
@norman.yuan I think that did it. I was expecting Autocad to not recognize the command; but it did. Thank you!
