How To Make block using vb.net
Hi All,
Suppose a make a drawing containing lines and arcs using vb.net. Now how can i combines   thses lines and arcs to make one block .
I also want to know, if above block is a closed figure , then how can i fill this closed block by hashed line.
Please help
Regards
Amit
gizmowiebe
Hi Amit,
you can do that by creating a selectionset and add the lines and arc to this selectionset. Check also
http://www.visiblevisual.com/index.php/AutoCad-VBA/createblock.html
regards
Wiebe
Hallex
This will get you started
static public void MakeBlockFromSS()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Transaction tr = db.TransactionManager.StartTransaction();
            Editor ed = doc.Editor;
            using (tr)
                try
                    SelectionFilter sf = new SelectionFilter(
                        new TypedValue[] { new TypedValue(0, "LINE,ARC") }
                    PromptSelectionOptions pso = new PromptSelectionOptions();
                    pso.MessageForAdding = "\nSelect arc and lines >>";
                    PromptSelectionResult res = ed.GetSelection(pso, sf);
                    if (res.Status != PromptStatus.OK)
                        return;
                    SelectionSet main = res.Value;
                    if (main.Count==0)
                        return;
                    ObjectIdCollection oids = new ObjectIdCollection(main.GetObjectIds());
                    ObjectId idx = AddHatch(oids, "ANSI37", 20.0, 0.0);
                    if (idx == ObjectId.Null)
                        ed.WriteMessage("\nProblem with creating boundary\ncheck gaps between objects\nProgram exiting");
                        return;
                    oids.Add(idx);
                    BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    PromptStringOptions psto =  new PromptStringOptions( "\nEnter new block name: "  );
                    psto.AllowSpaces = true;
                    string blkname = "";
                    do
                        PromptResult pr = ed.GetString(psto);
                        if (pr.Status != PromptStatus.OK)
                            return;
                        try
                            SymbolUtilityServices.ValidateSymbolName(  pr.StringResult, false );
                            if (bt.Has(pr.StringResult))
                                ed.WriteMessage( "\nA layer with this name already exists."  );
                            else
                                blkname = pr.StringResult;
                        catch
                            ed.WriteMessage(  "\nInvalid block name." );
                    } while (blkname == "");
                    BlockTableRecord btr = new BlockTableRecord();
                    PromptPointOptions ppo = new PromptPointOptions("\nPick Insertion Point >>");
                    ppo.UseBasePoint = false;
                    PromptPointResult pres;
                    pres = ed.GetPoint(ppo);
                    if (pres.Status != PromptStatus.OK)
                        return;
                    btr.Origin = pres.Value;
                    btr.Name = blkname;
                    btr.Units = UnitsValue.Millimeters;
                    btr.Annotative = AnnotativeStates.True;
                    bt.UpgradeOpen();
                    ObjectId ltId = bt.Add(btr);
                    bt.DowngradeOpen();
                    tr.AddNewlyCreatedDBObject(btr, true);
                    btr.AssumeOwnershipOf(oids);
                    tr.Commit();
                catch (System.Exception ex)
                    ed.WriteMessage("\n" + ex.Message + "\n" + ex.StackTrace);
                    return;
        static public ObjectId AddHatch(ObjectIdCollection ids, string pattern, double scale, double angle)
            ObjectId idx =ObjectId.Null;
            using (tr)
                try
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Hatch hatch = new Hatch();
                    btr.AppendEntity(hatch);
                    tr.AddNewlyCreatedDBObject(hatch, true);
                    hatch.SetDatabaseDefaults();
                    hatch.SetHatchPattern(HatchPatternType.PreDefined, pattern);
                    hatch.PatternScale = scale;
                    hatch.PatternAngle = Math.PI * angle / 180.0;
                    hatch.Associative = true;
                    hatch.Annotative = AnnotativeStates.True;
                    hatch.AppendLoop(HatchLoopTypes.Outermost, ids);
                    hatch.EvaluateHatch(true);
                    idx = hatch.ObjectId;
                    tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage(ex.Message);
                    idx = ObjectId.Null;
            return idx;
Change to your suit
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
marolek
i would like to write code to make and insert block using collection of ObjectId. I try do this basing on the hallex's code and now i have some like this:
Public Function zrob_blok(ByVal OBidy As ObjectIdCollection) As Boolean
  Dim oDWG As Document = Application.DocumentManager.MdiActiveDocument
  Dim oDB As Database = oDWG.Database
  Dim oTrans As DatabaseServices.Transaction = oDB.TransactionManager.StartTransaction
  Dim oBT As BlockTable = CType(oTrans.GetObject(oDB.BlockTableId, OpenMode.ForWrite), BlockTable)
  Dim oBTR As BlockTableRecord = New BlockTableRecord
  Dim retVal As Boolean = False oBTR.Origin = pktOtworu 'pktOtworu this is Public variable Geometry.Point3d
oBTR.Name = nazwaTXT.Text 'nazwaTXT - control on Form
        Try oBT.UpgradeOpen() Dim objekt As ObjectId = oBT.Add(oBTR) oBT.DowngradeOpen() oTrans.AddNewlyCreatedDBObject(oBTR, True) oBTR.AssumeOwnershipOf(OBidy) oTrans.Commit() Catch ex As System.Exception MsgBox(ex.Message, MsgBoxStyle.Information, "Error in zrob_blok") Finally oTrans.Dispose() End Try Return retVal End Function
but i have a problem bacause this work in a half
atfer this procedure block is created but not inserted to drawing,
any ideas to fix this problem?
Please help
Regards
marolek
Hallex
Have you tried to use 'Search' button at upper right of main page?
See a lot of threads here:
http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&location=Board%3A152&q=i...
~'J'~
