How to keep selection ?
Hallo to all!
My code takes the selected entities and reads out all the text of the attributes.
If no blocks are selected, the code prompts for a selection.
Unfortunately, by ending the transaction, the entitis are deselected.
So how to keep the selection, because it will be handled in a follow-up step.
thank you for any suggestion.
below a shortened code for the procedure:
private void Get_Text()
  Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView();
  PromptSelectionResult sel = edt.SelectImplied();
  if (sel.Status == PromptStatus.Error)
    TypedValue[] auswahl_typ = new TypedValue[] { new TypedValue((int)DxfCode.Start, "INSERT") };
    SelectionFilter auswahl_filtern = new SelectionFilter(auswahl_typ);
    PromptSelectionOptions pso = new PromptSelectionOptions();
    pso.MessageForAdding = "\nMake a selection";
    sel = edt.GetSelection(pso, auswahl_filtern);
    if (sel.Status != PromptStatus.OK)//
      edt.WriteMessage("\nSelection failed");
      return;
    }//if
  }//if
  try
    using (Transaction tr = db.TransactionManager.StartTransaction())
      using (DocumentLock dwg_lock = dwg.LockDocument())// Aktive Zeichnung wird wärend der Bearbeitung gesprerrt
		// Code for reading out the text form the choosen blocks
      }// using DocumentLock
    }// using Transaction
  }// try
  catch { edt.WriteMessage("\n#Error! Task failed"); }
}// void
_gile
In the Get_Text method, at the end of the code, add:
edt.SetImpliedSelection(sel.Value);
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
