How to jig a Spline (fit points) using AutoCAD 2013 .NET API?
How can I draw Spline with fit points in AutoCAD 2013 .NET API using my own jig?
Balaji_Ram
Here is a sample code that might help in getting started with jigging of spline. It is a modified version of the code from this blog post dealing with polyline jigging.
http://through-the-interface.typepad.com/through_the_interface/2010/12/jigging-an-autocad-polyline-w...
Here is the code :
using System;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
[assembly: CommandClass(typeof(SplineJig.SplineJigCmds))]
namespace SplineJig
	public class SplineDrawJig : DrawJig
		// members
		private Point3d _point;
		private Point3dCollection _points = new Point3dCollection();
		public Point3dCollection Coordinates
			get
				return _points;
		public SplineDrawJig()
		public void DoIt()
			Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
			PromptResult jigRes = null;
			do
				jigRes = ed.Drag(this);
				if (jigRes.Status == PromptStatus.OK)
					_points.Add(_point);
				else if (jigRes.Status == PromptStatus.None)
					break;
			while (jigRes.Status == PromptStatus.OK);
		protected override Autodesk.AutoCAD.EditorInput.SamplerStatus
		Sampler(Autodesk.AutoCAD.EditorInput.JigPrompts prompts)
			JigPromptPointOptions jigOpts = new JigPromptPointOptions();
			jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.NullResponseAccepted);
			jigOpts.Message = "Select fit point: ";
			PromptPointResult jigRes = prompts.AcquirePoint(jigOpts);
			Point3d pt = jigRes.Value;
			if (pt == _point)
				return SamplerStatus.NoChange;
			_point = pt;
				return SamplerStatus.OK;
			return SamplerStatus.Cancel;
		protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
			if (_points.Count == 0)
				return true;
			Point3dCollection vertices = new Point3dCollection();
			foreach (Point3d point in _points)
				vertices.Add(point);
			vertices.Add(_point);
			int totalVertices = vertices.Count;
			if(totalVertices >= 2)
				Line chordLine = new Line(vertices[totalVertices - 1], vertices[totalVertices-2]);
				draw.Geometry.Draw(chordLine);
			Spline spline = new Spline(vertices, KnotParameterizationEnum.Chord, 3, 0.0);
			draw.Geometry.Draw(spline);
			return true;
	public class SplineJigCmds
		public SplineJigCmds() { }
		[CommandMethod("SplineJig")]
		static public void SplineJig()
			try
				Database db = ed.Document.Database;
				SplineDrawJig splineJig = new SplineDrawJig();
				splineJig.DoIt();
				// order of the curve can be between 2 and 26
                int order = 6;
                // determines extent of interpolation through all the points
                double fitTolerance = .5;
				Spline spline = new Spline(splineJig.Coordinates, KnotParameterizationEnum.Chord, 3, 0.0);
				using (Transaction tr = db.TransactionManager.StartTransaction())
					BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
					btr.AppendEntity(spline);
					tr.AddNewlyCreatedDBObject(spline, true);
					tr.Commit();
			catch (System.Exception ex)
				MessageBox.Show(ex.Message, "Exception", MessageBoxButtons.OK, MessageBoxIcon.Error);
 Hope this helps.
Balaji
Developer Technical Services
Autodesk Developer Network
Thank You for answer. Perfect solution!
SRSDS
I'd like to add an rotated entity to the ends of the spline.
The Spline.StartFitTangent is giving a result of (0,0,0)
Is there another way of getting the angle of the start and endpoints?
hgasty1001
you can obtain the tangent angle from the first derivative of the curve with: MySpline.GetFirstDerivative(AtSomePoint), check the docs for others method that the curve class have.
Gaston Nunez
SRSDS
Thanks Gaston!
