How to Insert a Block with Preview Shape Following the Cursor?
viper_007
viper_007
Hi, everyone!
I try to used "SendStringToExecute("._insert ", true, false, false)", it does well except that I don't need the insert block form showing. I know the block's name exactly, and I'd like to insert the block directly with the block's preview shape following the mouse cursor.
聚傲气于一身,显傲骨之精华
cadprogramming
Instead of "._Insert" try "-INSERT".
The dash in front of insert will cause the command to be run from command line instead of dialog.
You will need to feed the command the right arguments so try it at command line first.
CAD Programming
viper_007
Thank you, you do me a great favor!
聚傲气于一身,显傲骨之精华
