How to get the "Support File Search Path" with code?
Message 1 of 12
Hi:
I would like to get de  "Support File Search Path" and "Working Support File Search Path" from Option in menu "Tools".
With VBA the name of dictionay was `DWGPROPS' and I used
Const DICTIONARY_NAME = "DWGPROPS"
Set DwgInfo = ThisDrawing.Dictionaries(DICTIONARY_NAME)
DwgInfo.GetXRecordData DataType, Data
but with .NET the dictionary name isn´t "DWGPROPS"
thanks
Replies (11)
Message 2 of 12
ApplicationServices.Application.AcadApplication.Preferences.files.SupportPath
same for all the other "options"..
ApplicationServices.Application.AcadApplication.Preferences.files.____________
Message 3 of 12
Alexander.Rivilis
Another way is:
string support_path = Application.GetSystemVariable("ACADPREFIX") as string;
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 12
it is easier than it thought!
thaks,
Message 5 of 12
StormyC
ACADPREFIX
Is there a way to edit this programatically?  ie add some file support paths?
Message 6 of 12
how can i get the exact code for other list folders, for example"Automatic SAve File Location"
Message 7 of 12
Gepaha
string autoSavePath = Application.GetSystemVariable("SAVEFILEPATH") as string;
Message 8 of 12
norman.yuan
 Not all file paths in the "Options->Files" dialog box have a corresponding system variables. If the ones you need to reach as corresponding system variables, such as "automatic save location", then using system variable "SAVEFILEPATH", as @Gepaha suggested, would be easy and simple. For others, you can reach them by
Application.Preferences, which is an AcadObject (COM API object).
So the code would be like:
dynamic preferences = Autodesk.AutoCAD.ApplicationServices.Application.Preferences;
var autoSavePath = (string)preferences.Files.AutoSavePath;
var supportPath = (string)preferences.Files.SupportPath;      // paths separated with ";"
var teplatePath = (string)preferences.Files.TemplateDwgPath.
Norman Yuan
Drive CAD With Code
Message 9 of 12
Thankx.
But i want to have it in the form
ApplicationServices.Application.AcadApplication.Preferences.files.____________, what should i give? I have tried with AutoSavePath but doesnt work
Message 10 of 12
Thx.
But i have tried for "Automatic Save File Location" with "Application.AcadApplication.Preferences.files.AutoSavePath", it turned to be invalid argument.
Message 11 of 12
Gepaha
You need to better explain what you want to do.
Are you using a listbox on windows forms? Exactly what do you want to add?
It is best to post the code.
Message 12 of 12
I was using a python node in Dynamo to add new file path to Options under different list folders. What i want is how should i change the code "SupportPath" in order to add new path under the list folders "Automatic Save File Location" and "Temporary External Reference File Location". Here is my code in a Python node:
# Load the Python Standard and DesignScript Libraries
import sys
import clr
# Add Assemblies for AutoCAD and Civil3D
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AecBaseMgd')
clr.AddReference('AecPropDataMgd')
clr.AddReference('AeccDbMgd')
# Import references from AutoCAD
from Autodesk.AutoCAD.Runtime import *
from Autodesk.AutoCAD.ApplicationServices import *
from Autodesk.AutoCAD.EditorInput import *
from Autodesk.AutoCAD.DatabaseServices import *
from Autodesk.AutoCAD.Geometry import *
# Import references from Civil3D
from Autodesk.Civil.ApplicationServices import *
from Autodesk.Civil.DatabaseServices import *
path = IN[0]
Application.AcadApplication.Preferences.Files.SupportPath += “;” + path
OUT = Application.AcadApplication.Preferences.Files.SupportPath.ToString().split(";")
