How to get intersection points of 2 blocks using vb.net?
Message 1 of 1
I want to check 2 blocks are intersecting each other and also intersection of block and hatch. I have used explode the block and check intersect with other block(outer polygon), but I didn't get the desired output(intersection points).  Kindly guide me how to get the intersection point between 2 blocks. Thank you.
Replies (0)
