- Mute
- Permalink
- Report
Hello, I would like to know how I can update the "InsulationThickness" and "insulationType" properties through the .NET API for Plant 3D. I tried to use the DataLinksManager by passing the SetProperties method, however, it does not contain the properties within the "Process Line" TAB.
Does anyone know how I can update the properties of objects within Process Line?
The only thing I found was this information inside the table in SQL Server called "P3dLineGroup".
However, I need to define this directly through the API.
