How to find the shortest distance between two skew lines using vector math.
Yehoshua18
Yehoshua18
Hey, I've been trying to figure out how to find the shortest distance between two skew lines. I can do it in C# without using AutoCAD vectors, but it would be much more simple if I could use them. Any idea how to make it happen? Thanks!
https://www.toppr.com/guides/maths/three-dimensional-geometry/distance-between-skew-lines/
Yehoshua18
I figured it out. Just incase anyone ever needs this, here is the solution.
public static void Interference(Line L1, Line L2)
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Vector3d U1 = L1.StartPoint.GetVectorTo(L1.EndPoint);
            Vector3d U2 = L2.StartPoint.GetVectorTo(L2.EndPoint);
            Vector3d N = U1.CrossProduct(U2);
            double nmag = N.Length;
            Vector3d P1P2 = L1.StartPoint.GetVectorTo(L2.StartPoint);
            Double Distance = Math.Abs(P1P2.DotProduct(N)/nmag);
            doc.Editor.WriteMessage(string.Format("\n Minimum Distance between lines {0} =",Distance.ToString()));
