How to extrude imported dxf along polyline?
Message 1 of 9
I have region is in external dxf file,
how to extrude it along polyline?
I can't get region after using dxfin method
                    Database myDxfDb = new Database(false, true);
                    myDxfDb.DxfIn(filename, logFilename);
                    Matrix3d dxfTrf = Matrix3d.Identity;
                    _ThisDatabase.Insert(dxfTrf, myDxfDb, true);
                    _ThisDatabase.UpdateExt(true);
                    myDxfDb.Dispose();
                    acTrans.Commit();
                    ObjectId id = AcUtils.EntLast();
                    Entity _ent = (Entity)acTrans.GetObject(id, OpenMode.ForWrite);
Replies (8)
Message 2 of 9
Alfred.NESWADBA
look to the objecttype that is the result of inserting the DXF ==> is it a region or is it a block(definition/-reference....) 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 9
dxf file contain only one region object
Message 4 of 9
Alfred.NESWADBA
and now try to insert this DXF into another drawing ==> what does it get then?
- alfred -
Alfred NESWADBA
Message 5 of 9
Hi alfred,
yes, I can that. dxf import as block reference.
well, how can I use this block reference 🙂
Message 6 of 9
Alfred.NESWADBA
either explode it or use the BlockTableRecord from this object to get the parts of this blockdefinition, there you also find then the region. You can then create an extrusion if this and add it to the database.
Good luck, -  alfred -
Alfred NESWADBA
Message 7 of 9
Alfred.NESWADBA
and a sample for how to create 3D-solids from 2D-objects could be found >>>here<<< (and Kean Walmsley has a lot more interesting samples on his site)
- alfred -
Alfred NESWADBA
Message 8 of 9
thanks a lot for your interrest alfred,
but my problem is not extrude region. I cant get region from dxf file.
Message 9 of 9
I found the solution
        public Entity ImportDxfAsEntity(string FileName, Point3d InsertionPoint, double Rotation = 0)
            ObjectId blkid = ObjectId.Null;
            Entity ent = null;
            using (Database bdb = new Database(false, true))
                bdb.DxfIn(FileName, @"c:\log.txt");
                //blkid = _ThisDatabase.Insert(System.IO.Path.GetFileNameWithoutExtension(FileName), bdb, true);
                blkid = _ThisDatabase.Insert("blok", bdb, true);
                using (Transaction tr = _ThisDatabase.TransactionManager.StartTransaction())
                    BlockReference bref = new BlockReference(InsertionPoint, blkid);
                    using (BlockTableRecord btAttRec = (BlockTableRecord)bref.BlockTableRecord.GetObject(OpenMode.ForWrite))
                        foreach (ObjectId subid in btAttRec)
                            ent = (Entity)subid.GetObject(OpenMode.ForRead);
                    tr.Commit();
            return ent;
