How to draw a line by direction and base point3D using C#
kite15
kite15
Is there any function by which we can create an unbound line object by direction and a base point?
The line can be created by two points. Is there any option to create any line by direction also?
Line ln = new Line(BasePoint, SecondPoint);
Thanks in advance
norman.yuan
Maybe, you want a Ray?
Norman Yuan
Drive CAD With Code
_gile
In addition to what @norman.yuan said.
Your question is not very clear. An "unbound line" may be a Ray (which has a start point and extends to infinity in one direction) or an Xline (which extends to infinity in both directions).
Both types have a constructor which take a (start) point and a vector (direction).
A Line is a linear segment which has a StartPoint, an EndPoint and a Length property, so it can't be defined with only one point and a vector.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
kite15
Thank all of you, for your suggestions.
