How to determine the version of AutoCad DWG file using vb.net
Message 1 of 8
As far as I googled everyone suggest this way.
How can the version of an AutoCAD DWG file be determined?
The first 6 bytes of a DWG file will indicate the version used.
1. Open the DWG file in Notepad.
2. get the first 6 bytes. its dwg version.
AC1027 AutoCAD 2013/2014
AC1024 AutoCAD 2010/2011/2012
AC1021 AutoCAD 2007/2008/2009
AC1018 AutoCAD 2004/2005/2006
AC1015 AutoCAD 2000/2000i/2002
AC1014 Release 14
AC1012 Release 13
AC1009 Release 11/12
AC1006 Release 10
AC1004 Release 9
AC1003 Version 2.60
AC1002 Version 2.50
AC1001 Version 2.22
AC2.22 Version 2.22
AC2.21 Version 2.21
AC2.10 Version 2.10
AC1.50 Version 2.05
AC1.40 Version 1.40
AC1.2 Version 1.2
MC0.0 Version 1.0
How can check the dwg version using VB.Net.
Any source code help or suggesion is appreciated.
Thanks in advance,
thenndral.
Replies (7)
Message 2 of 8
I'm looking for someone help/suggestion.
Message 3 of 8
_gile
You may have a look at the System.IO.StreamReader class (and the other classes which inherit from System.IO.Stream abstract class).
C#
private static string DwgVersion(string filename)
    using (StreamReader reader = new StreamReader(filename))
        switch (reader.ReadLine().Substring(0, 6))
            case "AC1027": return "AutoCAD 2013";
            case "AC1024": return "AutoCAD 2010";
            case "AC1021": return "AutoCAD 2007";
            case "AC1018": return "AutoCAD 2004";
            case "AC1015": return "AutoCAD 2000";
            case "AC1014": return "AutoCAD R14";
            default: return "Prior AutoCAD R14";
F#
let dwgVersion (filename: string) =
    use reader = new StreamReader(filename)
    match reader.ReadLine().Substring(0, 6) with
    | "AC1027" -> "AutoCAD 2013"
    | "AC1024" -> "AutoCAD 2010"
    | "AC1021" -> "AutoCAD 2007"
    | "AC1018" -> "AutoCAD 2004"
    | "AC1015" -> "AutoCAD 2000"
    | "AC1014" -> "AutoCAD R14"
    | _        -> "Prior AutoCAD R14"
VB
Private Function DwgVersion(filenameAs String) As String
    Using reader As New StreamReader(filename)
        Select Case reader.ReadLine().Substring(0, 6)
            Case "AC1027"
                Return "AutoCAD 2013"
            Case "AC1024"
                Return "AutoCAD 2010"
            Case "AC1021"
                Return "AutoCAD 2007"
            Case "AC1018"
                Return "AutoCAD 2004"
            Case "AC1015"
                Return "AutoCAD 2000"
            Case "AC1014"
                Return "AutoCAD R14"
            Case Else
                Return "Prior AutoCAD R14"
        End Select
    End Using
End Function
Gilles Chanteau
GileCAD
GitHub
Message 4 of 8
Thank you so much.
Its works perfectly.
Thanks again!
thenndral
Message 5 of 8
CADbloke
the 2004 version is actually AC1800, not AC1018. Thanks for the code Giles.
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
Message 6 of 8
Jedimaster
This cannot be used on the active drawing can it?
Message 7 of 8
_gile
In the active drawing, you can use the Database.OriginalFileVersion or Database.LastSaveAsVersion property:
var version = db.LastSavedAsVersion;
if (version == DwgVersion.MC0To0)
    version = db.OriginalFileVersion;
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
Jedimaster
Thanks, that works!
