Message 1 of 1
How to define hatch boundary with Ellipse using Internal point
I have this Cylinder like shape drawn using two Ellipse on top and bottom connected using lines. I want to fill this area with hatch.
here is my sample code, which is working. But I want to do this using internal point.
[CommandMethod("Test", CommandFlags.UsePickSet)]
public static void Test()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
// Define the center point, major axis, and minor axis
Point3d centerBottom = new Point3d(0, 0, 0);
Point3d centerTop = new Point3d(0, 1000, 0);
Vector3d majorAxis = new Vector3d(500, 0, 0);
double minorAxisLength = 300;
double radiusRatio = minorAxisLength / majorAxis.Length;
// Create the ellipse at bottom
Ellipse ellipseBottom = new Ellipse(centerBottom, Vector3d.ZAxis, majorAxis, radiusRatio, Math.PI, 2 * Math.PI);
btr.AppendEntity(ellipseBottom);
tr.AddNewlyCreatedDBObject(ellipseBottom, true);
// Create the ellipse at top
Ellipse ellipseTop = new Ellipse(centerTop, Vector3d.ZAxis, majorAxis, radiusRatio, Math.PI, 2 * Math.PI);
btr.AppendEntity(ellipseTop);
tr.AddNewlyCreatedDBObject(ellipseTop, true);
Line leftLine = new Line(ellipseTop.StartPoint, ellipseBottom.StartPoint);
btr.AppendEntity(leftLine);
tr.AddNewlyCreatedDBObject(leftLine, true);
Line rightLine = new Line(ellipseTop.EndPoint, ellipseBottom.EndPoint);
btr.AppendEntity(rightLine);
tr.AddNewlyCreatedDBObject(rightLine, true);
ObjectIdCollection acObjIdColl = new ObjectIdCollection();
acObjIdColl.Add(ellipseBottom.ObjectId);
acObjIdColl.Add(leftLine.ObjectId);
acObjIdColl.Add(ellipseTop.ObjectId);
acObjIdColl.Add(rightLine.ObjectId);
// Create the hatch object and append it to the block table record
using (Hatch acHatch = new Hatch())
btr.AppendEntity(acHatch);
tr.AddNewlyCreatedDBObject(acHatch, true);
// Set the properties of the hatch object
// Associative must be set after the hatch object is appended to the
// block table record and before AppendLoop
acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31");
acHatch.Associative = true;
acHatch.PatternScale = 500;
acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl);
acHatch.EvaluateHatch(true);
// Commit the transaction
tr.Commit();
